19 x 9.5 rims
Normal offset is +49.
So with these rims you would have the external edge of the rim protruding 13 mm + 6 mm (1/4") = about 2 cm more on the outside.
Maybe still acceptable for not rubbing, to be checked.
Depends also on the tires you would install: if keeping 255/40 R19, it should be OK.
Marque
10-11-2015 05:59 PM
