1998 xj8 tail lamps and tag lights not working
I know this is an old post, but to anyone who has had this same problem as I have. The problem is in the turn signal switch. There is a very small wire that can break from its solder as you are constantly using the turn signal. Take off the steering wheel ignition covers around the turn signal and you will very carefully have to solder this wire back on. I believe mine was yellow. my mileage also was not working along with everthing else. This fixed it all.
RColquhoun (06-08-2013)
FS[SouthEast]: GenRad GDS-510 scan tool
johnnie ryall
10-19-2015 09:44 PM
