2 Trans fluid changes - still squawking! Who sells the additive?
#41
Update time, its long, so here we go..
I reformatted my old XP laptop, wiping the hard drive clean and doing a fresh reinstall. SDD seems to work smoother and with less hiccups.
I read the vin, and started a new session.
Immediately i notice something slightly different.
With the old install, When i used SDD with my car it would ask me a long list of rather obvious accessory options, such as navigation (yes/no) rear seat climate control (yes/no), heated front seats, cruise control type, and many others. All in all, it had about 15 drop down menus I had to complete every time i start a session.
After the fresh reinstall, I was only asked 3 configuration questions.. so already i felt i was off to a better start.
I went ahead and loaded campaigns and tried to reflash the TCM again.
previously, SDD called up calibration file z63y5657x350ww.phx which I later found out was for a ZF 4.2L NA.
this time it prompted z65y5656x350fed.phx, which is for a ZF 4.2L SC!
Reflashing took 7.5 minutes and was successful; my transmission is back up and running!
I checked on the ECM file. It called up calibration file N69.s42pm.bin, which appeared correct. M1keh made a thread about flashing the wrong calibration file, and how the correct one for an SC car had 's' in the filename
I went ahead and attempted to reflash the ECU, and everything went to sh*t almost instantly.
I begin the reflashing and 20 seconds in it fails. All lights on dash are on now . SDD prompts me to rectify by unplugging battery and retry. I try again with no success, it fails again within 10 seconds
FINALLY the 3rd time the reflashing commences, and takes about 7 minutes to successfully complete. (Battery voltages were stable the entire time btw)
lol @ 'Smooth Road'. I assume theres a calibration file for Third World Gravel roads?
Car is doing its adaptation cycle now.. however Im wondering if I should RESET adaptations or if CLEARING adaptations is all thats needed?
Anyhow im happy the car is back in business.
I really appreciate the advice and knowledgeable folks willing to help out.
Now I have only 1 more issue to solve:
Why does my nav system thinks its an x400? as a result, my dual zone climate control doesnt work.
ill be posting in the other thread for this issue.
Don B (04-09-2018)
#43
Received 13,504 Likes
Typically, the adaptations are cleared prior to reflashing the TCM, so I don't think you have to worry about it at this point. With the updated firmware I believe you should have a new blank slate, so just drive it for a few days and things should smooth out.
I'm anxious to know if the squawk is gone too!
Cheers,
Don
#44
#45
What is your reasoning? The OP is facing a potential valve body rebuild at the very least. What can it hurt to try a reflash first?
Cheers,
Don
AD2014 (04-20-2018)
#47
#48
After driving for a few days I have noticed smoother shifts, however my 3-4 squawk is STILL there. Anything over 50% throttle and its a long consistent squawking noise (Approx 500ms- 1000ms) that eminates from what sounds like the rear of the car. Lighter throttle (10-20%) provides a chirp. it occurs 3-4 only (also on 4-3 slightly )
I'm going to try one more thing: Clear (or Reset?) adaptations, Reflash TCM, and making sure trans is correct temperature before carrying out adaptation drive cycle. Last time the car wasnt fully warmed when i began driving it.
I was hoping perhaps the additive takes a while to bead itself into the clutch packs, but there hasnt been any improvement in the noise
I'm pretty much out of ideas at this point..
#49
#50
#51
Don B (04-12-2018)
#52
Don B (04-12-2018)
#53
Don B (04-12-2018)
#54
It never made sense NOT to clear the adaptations if reflashing!
#55
Just a brief follow up.
Been driving a while, and my squawk is still present. Its literally not better at all. I'm completely stumped at this point.
Ive noticed the noise is notably worse once car has been driven a while and is up to temperature..
Im completely baffled why the additive didnt improve it whatsoever. seriously, what the hell? My trans shifts so smooth too..
#56
This probably is a dumb question however when I reread this thread I do not see any specific details on how you did your two fluid changes which is why I ask.
What temperature did you complete the fluid change last time and did you do a check of the fluid level after driving it around a while after it cools back down to 40 degrees C as per ZF instructions? Plus was the transmission really level when you did this?
#57
I performed my last fluid change when the transmission temp was 32C/90F (outside temp was 30C/86F)
I jacked up car level and verified with checking.
I filled trans, and once fluid starting dribbling out @ 40-42 degrees I tightened up fill plug.
I shifted through all gears as I filled. Once it was full I shut it off let it cool down and turned it back on later to verify level was good.
#58
That sounds good.
I did the same on my transmission however after driving around a fair bit I checked my fluid level again at about 40 degrees C and I needed to pump in a bit more.
Even IF your transmission required a small additional amount of fluid, like mine did, it may not make any difference to your issue however if it were me I would want to cover all bases.
#59
Brief update on this issue.
The squawk is still there, no notable improvement. It is most pronounced when car is up to temperature after driving a few miles. Hot ambient (>90F) may also be a contributing factor.
There's something seriously f*cked with my trans, as the flushes and the additive didn't seem to help at all. Transmission shifts great apart from the noise.
I emailed Klaus @ CTSC who told me its likely a ' clutch hardware issue' aka the E clutch is toast.
Looks like I'll have to deal with the noise until it becomes an actual problem..
Don B (05-17-2018)
#60
