2004+/4.2 liter transmission dipstik
The only V8 that has a dipstick for the trans is XJR/XKR because the use a Mercedes Benz trans. Yours being an 04, you'll have the 6 speed ZF, you check it by removing the fill plug on the side of the trans, while running, between 30 and 50 degrees Celsius, and you should have a steady drip.
Time and reality eventually caught up with ZF, and they now recommend a fluid change. Here is a video from ZF on what a fluid change requires:
Be sure and change the sealing sleeve and use the upgraded pan bolts to. I prefer to use this guy as he knows ZF's forward and backwards!
Now I use the Lifeguard fluid because it has come down in price a lot and is about $19/liter.
The CTSC - ZF Parts
The CTSC - ZF Parts
The CTSC - ZF Parts
The CTSC - ZF Parts
KeithPerrin
03-22-2016 02:29 PM
FS[SouthWest]: Set of Detriot 20" Staggered BBS Wheels off 2004 XKR
XKRowner
03-19-2016 12:13 PM
hawaiianjag
03-17-2016 05:58 PM
