2004 Jag XJR Headlight Flicker
Check your turn signal stalk. You can get a full replacement from Rock Auto. It is easy to remove and open up. There are, if I recall correctly, four wires in there. I had similar issues and found one clearly cracked wire and one that was close to failure. I added two small extension pieces and shrunk tubed them and all is well.
I had the same problem on my 2003 XJ6, and a new steering binnacle lighting switch cured it. An inspection of the old switch showed that somebody before I got the car had fiddled with it, probably too mean to replace it. The same basic switch is used on other Jaguar models, so they are not too expensive.
XxSlowpokexX
10-16-2019 08:32 PM
djpxk8
02-28-2016 06:10 PM
