2004 Jaguar XJR - A/C Recharge
I am looking through the workshop manual to find specs on a/c refrigerant oil type, how many oz of refrigerant oil and refrigerant I need to charge the system with. In replacing the radiator a few weeks back, I accidentally opened the A/C system and lost all freon. Now the car is being put back together and I am to the point of needing to charge the A/C.
Any tips and pointers from folks that have been through this will be appreciated.
2000 XJRRRR (08-11-2020)
I went ahead and charged it the way I typically do other vehicles:
- I ran the vacuum pump for about 75 minutes. The system did hold vacuum at 29.5 in.Hg.
- I charged the system with 2 cans of R134a
> First can was A/C Pro first charge with ICE 32
> Second can was off the shelf AutoZone R123a
- Total charge: 22oz (624 grammes)
While it as charging the low port pressure was hovering around 30PSI or so.
After completing the charge, the following readings were obtained:
While A/C on max with ambient temperature of 65F (18C) my readings were as follows:
- Low pressure: 27PSI
- High pressure: 185PSI
- Vent temperature: 25F (-4C) (yeah, it was *that* cold)
Do not know if these are typical numbers given the ambient temperature and the amount of freon I used.
Comments welcome
Comments welcome
Thermite (06-27-2014)
2012 Vehicle Specs gives the refrigerant as R134a and the charge weight as 650±25g for the two zone system, and 800±25 for the four zone.
The compressor lubricant is part number JLM 12260 and is 140ml for the 2Z, 180 for the 4Z.
No info on pressures.
Edit:
Workshop Manual gives compressor lubricant as 'ND8'.
With the engine OFF the system pressure should be 60-80psi.
Yours aye
Dave in Gloucestershire UK
Edit:
Yours aye
Jaguar Forums Editor
Jaguar Press release
08-26-2015 05:08 PM
