2004 Powerfold Mirrors
Hello Everyone,
I have just purchased a 2004 Vanden Plas to replace my wrecked X308. All is fine with the replacement, but I can't tell if it has powerfold mirrors. The switch is there, and the owners handbook says it has them, but the original window sticker does not say so. Nothing happens when I use the switch (the button in front of the mirror direction switch), and the mirrors can be pushed to the folded direction. I didn't fully push them folded, as the handbook says not to force them folded. Did all VDP's have PF mirrors?
This is a great forum, with a wealth of information and very knowledgable members. Thanks to all.
First of all go into the touchscreen menu and look at Vehicle Settings.
You should see an option in there for the mirrors to fold on double-lock (along with two-stage unlocking, daytime running lights, and something else....)
If you don't see the option there for the mirrors to fold then the car doesn't have the folding mirrors fitted, or at least it thinks that they are not fitted.
Even though my XJR only has 35k/miles, my mirrors didn't appear to be folding at all, even though the Vehicle Settings said it was on.
So I hunted around for a while in here and was beginning to think I had some ugly gunked-up mechanisms - but then I spotted this post that said "double-click the lock on the key fob" and that proved to be the trick I was missing.
There's also mention of a button in front of the mirror directional control - but I don't seem to have that button.
Thank you old posts in the Forum!
If it really does have powerfold mirrors, but hasn't been touched since 2004, then it is likely the mirror assembly has seized due to corrosion accumulation.
You need to remove the mirror front cover, and clean all the crud you can find inside and lubricate the swivel post. The mirror may then "swing" into action. The corrosion crud appears due to the use of Mazak alloy by the makers of the mirror. Intrusion of salt and damp means the Mazak, (an alloy of zinc) starts to corrode and the corrosion products jam things up.
Thanks for the feedback, but perhaps I should have stated this more clearly in that last post...
When i did the 'ol double-press the Lock button on the Keyfob trick, they folded right up. When you press Unlock on the Keyfob, they unfold.
Lucky for me, they aren't gunked up at all.
Received 12,932 Likes
Hi MeatBag,
On our '04 the button for folding the mirrors is very, very small, it's black, and it's positioned in the black surround for the driver's window control panel a little forward and left of the outside mirror adjustment switches. It's easy to miss if you don't look closely. Are you sure your car doesn't have this tiny button?
Cheers,
Don
Received 9,006 Likes
Hi MeatBag,
Cheers,
Don
Cheers,
Don
Strange! Abonano has just discovered that adding the overhead console with the parking alarm disable button will add that feature to vehicles that were not originally so equipped (he's going to give us a full report soon - sorry for letting the cat out of the back abonano!). I wonder if you swapped the driver's switch panel for a salvaged unit with the folding mirror switch (ebay) if the switch would operate your mirrors?
Cheers,
Don
AD2014 (05-13-2014)
Hi Jim,
Which mirror behavior did you enable and then disable? Was it the "double press on the lock button to fold the mirrors in," or an automatic folding feature on engine shutdown, or something else?
Cheers,
Don
FS[NorthWest]: 2004 X-type 3.0 24,500miles! $8500
millertic
09-30-2015 08:11 PM
