2004 Vanden Plas Stiff Steering Over 13mph Only
#41
#42
Received 12,942 Likes
Our '04 XJR is definitely not difficult to steer under any condition or at any speed, so something must be malfunctioning. Did the mechanics test drive your car under the same conditions where you're experiencing the stiffness?
#43
Thanks.. they don't want my business because they know I'm too smart to price gouge... could putting it on the lift have messed up the rear air shock? Anyway testing for steering issue guy is almost doing donut and I tell him to chill out I don't want to break anything else.. the they seem pissed when I bring it back because air deflector was loose on back right..
Anyway, when cold, stopped, power steering really easy, once warm, it gets stiffer and whines... that's power steering pump wearing out right?
#44
#46
Guy at shop charged me $120 for diagnosis. I explained at least 3 times to check resistance on solenoid. He never did and just says the steering is normal. On a curvy road i find it a little to much effort to believe the car was designed that way. I guess I will have to check it myself. And they get grease all over the white interior. And mysterious scratches on the car. Then about to give me the car back with the bottom piece and engine cover missing. Then say its about lunch, come back in an hour. Every mechanic I have ever dealt with really annoys me...
If you're near North Hollywood, I can recommend Jack at North Hollywood Auto Repair. Him and his guys are the only mechanics I've ever trusted, more than any Jag specialist I've ever been to.
Also regarding steering, this car has the lightest easiest steering of any car I've ever driven and anyone who gets behind the wheel agrees. So resistance of any kind is definitely NOT normal.
#47
Which shop was this? I'm in the Los Angeles area also so I'm very curious.
If you're near North Hollywood, I can recommend Jack at North Hollywood Auto Repair. Him and his guys are the only mechanics I've ever trusted.
Thanks a million...
#48
Absolute on Hoover... said steering was normal..
Steves Jaguar in Canoga said steering was normal and he starts circling crazy, they leave bottom hanging, and now I have leaking rear air shock, ignore me in office, and seem mad I want the bottom plate secure.. bad vibes..
Both mechanics say iv driven tons of jags it's normal.. Steve turns ignition off while I'm driving and says .. that's no power steering...
Bad vibes both places...
#49
#50
Then I found what used to be Exclusive Jaguar on Venice, and I was very pleased with them until the new complete moron owner came along. He and his new crew were such idiots, it inspired me to finally get down and dirty and start doing my own maintenance and wrenching. But once in a while there's a job that's too big for me, and Jack at Noho Auto Repair comes through every time. They are 100% honest and reliable and recommend them to anyone who will listen.
Don B (09-18-2015)
#51
I've been to Steve's before. Years and years ago for a throttle body sensor issue. It took multiple trips for them to figure out the problem. I wasn't impressed with them and never went back.
I am pretty sure power steering pump is going out because after it warms up steering starts to fade even parked...
Thanks for the info...
#52
#53
Why no air suspension fault even though rear is sitting on bumpstops... did hard reset but nothing changed... Compressor not running... could relay be shot or compressor just toast from driving it a lot with major air leak... still don't know why no fault light... thanks...
There are lots of existing threads on similar air suspension symptoms. Search the forum to see what has already been reported and resolved by others. If you are still not able to resolve your problems, please start a new thread on your air suspension issues. It's helpful to keep topics like suspension issues and steering issues separate for the sake of clarity.
Thanks,
Don
AD2014 (09-25-2015)
#54
Solenoid was 8 ohms... it might be good, but no way to know for sure... do you think a weak power steering pump could be causing the problem.. once it warms up, even parked, with solenoid all the way open or closed (whichever position makes full assist), it gets stiffer...
It seems like if solenoid was sticking it wouldn't open and close so consistently at 9 - 13 mph...
Maybe if there were more pressure, the solenoid would open and close better???
I have the workshop manual but it is over 6000 pages and impossible for me to find the info I need..
I guess I should replace pump and go from there?? I don't want to keep throwing money at diagnostics with no real answers...
It does have a whining sound sometimes after warmup....
Fully cold, parked it works good..., but at 9mph it definitely all of a sudden goes to default stiff steering...
On a curvy road the steering is heavy...
Or maybe I'll try to find another mechanic.. 2 mechanics have already argued that it is normal, but I know they are wrong...
I have a 2004 vanden plas, which is basically identical as the 2004 xj8.. x350 chassis...
#55
#56
https://www.jaguarforums.com/forum/x...sducer-149078/
http://www.mediafire.com/download/md...f+contents.pdf
http://www.mediafire.com/download/aa...nformation.pdf
http://www.mediafire.com/download/n3...2.+Chassis.pdf
http://www.mediafire.com/download/9b...Powertrain.pdf
http://www.mediafire.com/download/0i...Electrical.pdf
http://www.mediafire.com/download/4j...+and+Paint.pdf
Cheers,
Don
AD2014 (09-25-2015)
#58
If the car steers hard when the solenoid is unplugged then I don't know.
The way VAPS works is fail safe. If the VAPS has a problem the default is full assist regardless of the speed.
From your other descriptions it sounds like you might have a P/S pump problem? The pump is common and cheap because all Jaguar 4.2L SC and NA engines as well as all Lincoln LS 3.9L from 2000-2006 use the same pump. I find it's about $60-$95 depending on where you get it. I think the same pump is also used on the Jaguar 4.0L but have not been able to confirm that.
Maybe change the pump first and see what changes? Pumps are not a known problem but after all these years and miles it may need replacing.
#59
