2004 Vanden Plas Suspension Question
Greetings:
Could someone tell me if there is a difference between the 2004 XJ8 rear lower / upper control arms and those on my 2004 VDP? I need to have the bushings replaced on my lower control arms, and for some reason, the order form states that the bushings are not compatible with the VDP, but will work on the XJ8. I don't want to order something that won't fit once my mechanic removes the control arms and has the old / worn bushings pressed out. My car squeaks like a bed with rusty springs and I believe that the problem lies with lower control arm bushings that are shot. Any help on the compatibility issue would be greatly appreciated.
Funny I should read this now. I have a 2004 vdp and purchased a bushing kit online, but decided to take it to my local mechanic to have changed out. I just assumed a vdp was the same as the xj8. I was wrong. After 2 days of heating/cooling/penetrating oil, they got the suspension arm bolts out of the car to find out the bushings I supplied were incorrect. I contacted the company, and they had no solution for me. I'm looking now to find out what else is different between these cars - I thought the VDP's were just a trim change for the same chassis.
Greetings:
slownlo
02-03-2016 12:53 PM
FS[Central US]: 2004 xjr $ 9500.00
belladad
02-03-2016 08:09 AM
