2004 vdp amp fuses
![Question](https://www.jaguarforums.com/forum/images/icons/icon5.gif)
Does anyone know where the fuse for the trunk mounted amp is located for the 2004 vdp with the media package.i know there is some on passenger side kick panel,in trunk near the apir and also some under the hood but where are they located for the actual amplifier>?any ideas?
![Thumbs up](https://www.jaguarforums.com/forum/images/icons/icon14.gif)
hello and thank you so much,but would you have a diagram of it because I do not have a owners manual with the car since it was purchased used.I have been racking my brain trying to get the media package to power up,but want to make sure its not a fuse ,because the amp is very expensive.If not a diagram could you point out the fuses in that area so ill know what to actually check?? thanks again my friend, Ill be posting some pictures of my CAT soon...
Hi,
The handbook is available to download at the top of this page.
I have a circuit diagram but I had to trace the fuse location and am not very good at attachments etc. The jaguar electrical guide is available on the internet
if you search for it-no link sorry.
If you describe the problem in more detail I'm sure that more people will try to help.
BTW There is an intermittent problem with radios etc going dead for no apparent reason and then coming back to life when the ign is switched on and off.
With respect to the fuses- the positions are numbered but not easy to see. I took a photo and then blew it up on the computer.
Hope this helps
Hope this helps
