2004 XJ8 117K - Front End Pulling
I just purchased my XJ8 in unknown condition. When I bought it the suspension had collapsed so I couldn't drive it before buying. Now that I have the air suspension fixed (see my other post) I find that the front end feels very vague and it pulls all over the place. When I go over bumps the car pulls one way or another and paint lines or irregularities in the road will cause it to pull around on me. I'm constantly having to correct course and hold the wheel to keep it straight. Is that just the way this car drives or do you think there is something wrong? I always expected this thing to be rock steady but mine feels very "busy" and vague. In it's current condition my Buick Lucerne would kick it's tail in a handling competition... handily! Surely there's something wrong... what are some things I should check right away in the front end? Any bushings that are common failure points?
+1 on what Rahnkey said. After a good and through inspection get the alignment performed at the dealer.
Years ago I had an XJ6 that pulled after multiple alignments at a big box store. When I called em on it, it turned out the tech did not have a proper shim for one of the adjustments so he just ignored it. They gave me my money back. I subsequently took it to a pro who pulled it right in after one try.
With your mileage, my guess is that you are going to find 1 or more suspension components badly worn. This should/must be corrected before alignment.
If you have a vague front end, there is definitely something wrong. My car tracks straight and true, and the tyres last well over 30k miles, so you need to get it to a 4-wheel alignment shop, but first get the front and rear suspensions checked out for wear.
Common wear items are: -
- front lower wishbone trunnions
- front upper wishbone trunnions ( usually much less common than the lowers that do most of the work)
- front wheel bearings
- rear lower wishbone bushes
- rear tracking arm ball joints
- anti-roll bar (sway bar) link rod ball joints front and rear
Steel ball joints last a long time, but eventually wear out, and are not replaceable separately, as there is no source for the items.
As well as this, the lower air spring bushes wear out quickly as they take the full weight of the car, but don't affect the handling, obviously, they just make a lot of noise and cause vibration.
If all that lot needs replacing, you're talking of a large sum of money even at internet prices.
Only thing to mention is that these cars are sensitive to side winds. I think this is because the car is large but the weight is low. I do notice this, but it doesn't seem to affect the stability of the car.
Of course you need to also check your tyres.
I've looked over the rear so far and certainly the sway bar link and tie rod boots are gone but the links themselves didn't feel loose when disconnected. Regardless I'll replace all of that.
Is there any aftermarket source for rear control arm bushes? I see some parts listed online for the front but not much for the rear.
I'll go up front next and inspect everything. I'm still waiting on my WDS package from British Diagnostics to arrive. I need to dig into some more suspension codes.
eBay
http://www.ebay.co.uk/sch/i.html?_js...ishbone+bushes
Pour boiling water on the arm when removing and refitting the steel-bodied bushes to reduce need for excessive force.
I pulled the front wheels off this weekend. Both front outer tie rods are shot as well as the upper ball joint. I'd like to replace the entire upper control arm but Jaguar wants and obscene amount of money for it. Does anyone know for sure if it is identical to the Lincoln LS upper control arm? Sure seems like it is. I'm going to try to find a Lincoln LS control arm locally and just do the comparison.
MC36
US Lower Atlantic
09-01-2015 07:34 PM
