2004 xj8 460 532 bbf build
Old 05-21-2017, 10:07 PM
04 xj8's Avatar
Default 2004 xj8 460 532 bbf build
I cant believe how well this 460 fits, its like ford designed it to fit,
i bought the car with a blown head gasket because the lady ran it out of coolant 1100 bucks so yay!
this 532 made 610 hp 650 ft lbs to the crank, 7800 dollar engine build.
i thought i would share this, look at all the room, the one pic the engine is lying in there unbolted, the others its bolted up with jaguar mounts.
i can fit two bolts in those mounts if I oblong one hole an 8th inch.
block hugger headers have tons of room and even fit the factory exahust, no mods.
ford slip yoke driveshaft should cut and slide onto the jag shaft i hope.
i just started this build so bear with me for month or so as i have a race c6 on its way, hope it fits.
Attached Thumbnails 2004 xj8 460 532 bbf build-img_0377.jpg   2004 xj8 460 532 bbf build-img_0378.jpg   2004 xj8 460 532 bbf build-img_0379.jpg   2004 xj8 460 532 bbf build-img_0380.jpg   2004 xj8 460 532 bbf build-img_0381.jpg
2004 xj8 460 532 bbf build-img_0382.jpg   2004 xj8 460 532 bbf build-img_0383.jpg
Old 05-22-2017, 11:27 AM
Wingrider's Avatar
Looks like a fun project!
Old 05-22-2017, 12:44 PM
XJ8JR's Avatar
Wow. Looking forward to updates.
Old 05-22-2017, 10:26 PM
Mark in Maine's Avatar
Is that without being blown? 610 hp N/A?
Old 05-22-2017, 11:36 PM
chillyphilly's Avatar
Nice build. What part of Idaho are you in?
Old 05-23-2017, 06:14 AM
mhamilton's Avatar
Once you get the DOHC heads out of the way the engine bay is cavernous!
Not to hijack your thread--noticed the Jag fuel rail in your pics. Any chance you could measure the resistance of that fuel rail temp sensor? Just looking for a room ambient measurement. If you're going to toss it I'd buy it from you. PM me if you can.
Thanks,
-Michael
Old 05-26-2017, 09:23 AM
This blows away the old XJS Chevy conversion. They always ran hot/overheated.
Old 05-27-2017, 12:00 PM
Zazzy's Avatar
This looks like a fun project. I have a race C6 sitting in my garage that used to be hooked up to a 700+ HP 358 Yates engine. Now I have an idea what to do if the stock engine dies. Maybe a streetable Ford SB with a newer tranny would the great swap.
I had 85 ford truck that had a built 460. You can get tons of HP and torque on pump gas, non-aspirated. 600 HP is easy.
Have fun! Post more.
Old 05-29-2017, 02:30 PM
genec's Avatar
I think my 2004 xj8 is plenty fast enough with the stock 294 hp engine. Runs much better then my 2001 with 290 hp . 610 hp is just scarry!
I wonder if a 460 would fit in my '72 450sl?
It's too bad Ford never hot-rodded the 460 like they did the 429. I remember an ad from 1976 or so for a Mercury Marine 460 boat engine that put out 600 foot-pounds of torque at 1000 rpm.
Anyway, Will be interesting to see how this turns out. I hope the rear axle can handle that much power.
Old 05-30-2017, 10:27 PM
Can a Quaife handle that kind of HP/torque?
Old 05-30-2017, 10:32 PM
You should try a SV8!
genec (06-01-2017)
Old 06-01-2017, 10:38 AM
hisport's Avatar
Great!!!
This really is making a stone axe out of a scalpel. Your engine pics look like the underhood of my neighbor's '67 Thunderbird convertible (which I've seen rather too often)
Any chance you could use that lovely 6 speed ZF rather than a crude old 3 speed c6? No idea whether the bell housing would match, and you would have to bodge the TCM, I imagine
If you're really making 600HP with that huge carbureted cast iron push rod two valve lump, it must have a really big cam. Do you plan to use a high stall speed converter?
As you probably know, the open diff on these cars will make using all that torque a frustrating (and smokey) affair. There's an expensive LSD available I think (Quaife?)
Just for curiosity, did you happen to weigh the OE engine/trans vs the 460/C6 combo?
Please keep us posted as you progress with things. And, have fun!
Old 06-01-2017, 10:52 AM
Wingrider's Avatar
Funny car type of builds,really never make a lot of sense.They are just a fun type example, of no success like excess
Old 06-01-2017, 05:33 PM
genec's Avatar
Or this one!
Arden XKR coup
Old 06-02-2017, 09:46 PM
04 xj8's Avatar
I had a engine builder build it for me, made 610 to the crank, n/a hp, he is extremely good at what he does.
Old 06-02-2017, 09:50 PM
04 xj8's Avatar
Originally Posted by hisport
Great!!!
yea there is nothing stock about this motor, lol roller rockers cam heads stroker kit balanced blueprinted port polished, 10.5.1 etc etc, im worried its too much power for the rear axle but i am willing find out, hope it holds up.
Old 06-02-2017, 09:54 PM
04 xj8's Avatar
that is a little close, ill have to flatten the engine mount bar to slide it a half inch back!
Old 06-02-2017, 09:56 PM
04 xj8's Avatar
plenty of room to move this a half inch back
Old 06-02-2017, 09:57 PM
04 xj8's Avatar
that bar is a universal engine mount from summit, it fits fantastic, i decided to not use the factory jaguar engine mounts because the engine set too high to clear hood, it sets on the cradle very nice, the ends need to be oval just enough to scoot the assembly back just a touch, right now its sandwiched in between the aluminum rails and cradle.
Old 06-02-2017, 10:01 PM
04 xj8's Avatar
the engine is setting about where it needs to, its bolted down, look at how well the filter clears and all that room to run block huggers oh and ac lines are going away.
