2004 xj8 air conditioning whine
recently purchased a 2004 xj8 with 60k miles...love the car...BUT i do have a whining/grinding sound (similar to power steering whine noise) ONLY when air conditioning or fan system is on. if i turn off fan system the noise goes away within 2 seconds. the noise does not appear to negatively impact performance but it is annoying....any ideas? THANKS!
From what you say, the noise is potentially coming from two places, the air con compressor or the fan that will come on at the same time. You need to determine which. On my previous c car, a Rover 75, I started to get a whining noise, and this disappeared when I turned off the air con. On this car, there was only a single fan which ran to cool the car as well as the air con condenser. So I found that the compressor was making the noise and was lucky enough to find a brand-new on on the Internet at a very reasonable price so I replaced it and the whine disappeared.
Worth checking the refrigerant level, as this also contains lubricant for the compressor, so if its low, there may not be enough lube.
At about 60,000 miles the A/C system broke on my 04 XJ. The dealer said that time (age) is as much of a factor to these systems as usage. The bearings seized up because the seals went bad and the lubricant seeped out. There was minimal noise before it broke; but when it broke it made the car stall out and I had to have it towed. The job cost about $2,400 (fortunately I had an aftermarket warranty that picked up the tab). There was zero impact to performance before it broke; I'd get it looked at right away.
My 04 has got a similar problem. The whine starts after about 5 minutes of driving and is quite noticeable when driving around town. It rises and falls with the engine revs. At first I thought it was the engine or gearbox but then noticed that pressing the A/C switch to disable the compressor makes the noise go away.
I will probably get the refrigerant level checked next time the car is in for a service.
Mine has the whine, it's normal, just unusual, I've never had another car do this. It's most noticeable when accelerating in the summer with the AC on. I can't explain why this particluar car does this but it might have something to do with the design of the serpentine belt system. Everything else is standard stuff.
Kind regards,
Eric
My '05 XJR makes a distinctly different noise when the A/C is running than when the A/C is off. The noise only happens under acceleration, and to me it sounds like a spooling sound, and it always sounded a bit unusual, but somehow "normal". I assumed it was the way the compressor the pulley/clutch assembly is supposed to sound under load.
Note the age of the original post. However, a slight whine from the AC compressor can start after some miles, (I had it on my car recently), but may be cured by a regas, which will replenish the compressor lubrication at the same time, as lube is normally part of the recharge.
My whine disappeared when I had an AC service recently. If it persists, then a new compressor is probably needed to eliminate it entirely, but I think these things can whine away for quite some time before its 'replace' time.
The following 2 users liked this post by Fraser Mitchell:
Eric van der Linden (11-03-2012),
SuperTrav (11-03-2012)
I finally had my system emptied and refilled and the noise has gone completely.
The sound it made before was totally dependent on engine revs so it had to be the compressor. These Denso compressors don't have a clutch like older systems but according to my A/C specialist they are always connected to the crankshaft. Even so the noise always stopped after a few seconds after I switched off the A/C probably because it reduces the flow rate.
My system only held 150 grams instead of the 600 grams that should have been in there.
If a compressor is still noisy after a regas you probably need a new one.
meirion1 (11-10-2012)
![Icon Rain](https://www.jaguarforums.com/forum/images/smilies/icon_rain.gif)
Mugatu
22
06-23-2020 01:50 PM
