2004 XJ8 Battery removal and Install
I have had my XJ8 in storage during pandemic out in Ca. ( My own garage) and had someone running car less then couple miles once a month. Yep - dead battery after a few starts and depleted starting amps ( battery was new 3 years ago) . My question - I plan to R&R battery when I get back to Ca. with XJ8 spec replacement from O'Reilly .. I am familiar with the trunk layout - and realize it will be a pretty heavy lift out. What I need some guidance on is how is this battery vented to the outside ? - Are their connection hoses as one battery tech mentioned, or is there a passive vent like a opening not seen from above. Does any one have any jpeg or pdf pictures of the battery removal.
Data from battery store suggests professional install recommended - however with car in garage - I would rather not flat-bed car out to my regular jag mechanic if possible.
Thanks -
Thanks -
