2004 XJ8 A/C water in Rear Passenger floor well
where have drenaje of water from A/C?
There is also a plenum chamber drain where the air enters the CC unit. This is underneath a cover at the back of the engine compartment on the passenger side. The cover is easily removed and has a grill moulded in it for the air to enter. If this drain hole blocks, water can enter the CC unit.
However, if the water is in the rear compartment, it could be a leak somewhere else. Jaguar had a TSB on this, I believe.
philwarner
09-05-2015 10:05 AM
