2004 XJ8 coolant expansion tank replacement
Old 07-04-2020 | 09:39 PM
goldgun's Avatar
Default 2004 XJ8 coolant expansion tank replacement
the nipple broke off my coolant tank,is this a DIY job,any idea whats involved,also what is the best brand of aftermarket? or should I go with OEM
thanks in advance
Albert
Old 07-05-2020 | 12:58 PM
Wingrider's Avatar
Easy job, seems the ones from China work well enough.
Old 07-05-2020 | 03:04 PM
goldgun's Avatar
Thanks Wingrider,one more question,is there a O ring that you should changed on the hose with the metal clip that attachs to the tank
thanks
Albert
Old 07-05-2020 | 04:14 PM
Wingrider's Avatar
Not on mine, just don't loose that metal snap ring.
wydopnthrtl
08-23-2018 06:38 PM
carzaddict
04-23-2018 11:44 AM
Unshriven
03-11-2014 07:24 PM
JaggyZ639
01-02-2014 07:46 PM
scubayachts
10-20-2010 01:18 PM
Quick Reply: 2004 XJ8 coolant expansion tank replacement
