2004 XJ8 Engine Light on throwing P0829 code
Auto transmission . ZF6HP26 ON ALL X350/358
OIL LEVEL fill plug screw left side on the transmission open should overflow a little dribble when oil at min 40 degrees centigade.
Next your rear reluctor rings or the wheel speed sensors hidden on the outside left and right just behind the brake discs. Can cause the same
