2004 XJ8 engine shutoff while driving
I own a 2004 XJ8 (V.8 4.2L) with 37K miles. Haven't had many problems with the car before but I was driving at about 30 MPH yesterday when suddenly the car just shuts off. The dashboard said ENGINE FAULT, DISC NOT AVAILABLE, AND PARK BRAKE FAULT. I turned the ignition to the off position, then turned it back on immediately. The car started immeadiately with no problems and I continued driving normally. I went to AutoZone to check if I could find any codes that could be found with their hand-held diagnostic reader. It came up with the code P1111 which was generic in their database for multiple cars manufacturers. Can anyone explain what the code P1111 is for Jaguar and was is the fix?
P1000 OBD Systems Readiness Test Not Complete
P1104 Mass Air Flow Sensor Circuit Ground - Read Our Article On Automotive Circuit Testing For Help With This Jaguar Check Engine Light Code
P1111 System Pass
P1121 Pedal Position Sensor A Circuit Range/Performance
P1122 Pedal Position Sensor A Circuit Low Input
P1123 Pedal Position Sensor A Circuit High Input
P1136 Control Box Fan Circuit - Read Our Article On Automotive Circuit Testing For Help With This Jaguar Check Engine Light Code
P1137 Lack Of HO2S12 Switches - Sensor Indicates Lean - Read Our Article on Oxygen Sensor Codes For Help With This Jaguar Check Engine Light Code
P1138 Lack Of HO2S12 Switches- Sensor Indicates Rich
P1143 Air Assisted Injector Control Valve Range/Performance
P1144 Air Assisted Injector Control Valve Circuit - Read Our Article On Automotive Circuit Testing For Help With This Jaguar Check Engine Light Code
P1157 Lack Of HO2S22 Switches - Sensor Indicates Lean - Read Our Article on Oxygen Sensor Codes For Help With This Jaguar Check Engine Light Code
P1158 Lack Of HO2S22 Switches - Sensor Indicates Rich
P1171 System Too Lean- Banks 1 And 2 (Lean Fuel Fault)
P1172 System Too Rich - Banks 1 And 2 (Rich Fuel Fault)
P1174 System Too Lean - Banks 1 And 2 (Suspect HO2S)
P1175 System Too Rich - Banks 1 And 2 (Suspect HO2S)
P1176 Long Term Fuel Trim Too Lean - Banks 1 And 2 (FMFR) - Read Our Article on Oxygen Sensor Codes For Help With This Jaguar Check Engine Light Code
P1177 Long Term Fuel Trim Too Rich - Banks 1 And 2 (FMFR)
P1178 Long Term Fuel Trim Too Lean - Banks 1 And 2 (AMFR)
P1179 Long Term Fuel Trim Too Rich - Banks 1 And 2 (AMFR)
P1185 O2 Sensor Heater Circuit Open - Hardware Fault
P1186 O2 Sensor Heater Circuit Shorted- Hardware Fault
P1187 O2 Sensor Heater Circuit Open - Inferred Fault
P1188 O2 Sensor Heater Circuit Resistance
P1189 O2 Sensor Heater Circuit Low Resistance Fault 1
P1190 O2 Sensor Heater Circuit Low Resistance Fault 2
P1191 O2 Sensor Heater Circuit Open - HArdware Fault
P1192 O2 Sensor Heater Circuit Shorted
P1193 O2 Sensor Heater Circuit Open - Inferred Fault
P1194 O2 Sensor Heater Circuit Resistance Fault
P1195 O2 Sensor Heater Circuit Low Resistance Fault 1
P1196 O2 Sensor Heater Circuit Low Resistance Fault 2
P1198 Fuel Level Input Circuit High
P1199 Fuel Level Input Circuit Low
P1201 Cylinder # 1 Injector Circuit Open/Shorted - Read Our Article On Automotive Circuit Testing For Help With This Jaguar Check Engine Light Code
P1202 Cylinder # 2 Injector Circuit Open/Shorted
P1203 Cylinder # 3 Injector Circuit Open/Shorted
P1204 Cylinder # 4 Injector Circuit Open/Shorted
P1205 Cylinder # 5 Injector Circuit Open/Shorted
P1206 Cylinder # 6 Injector Circuit Open/Shorted
P1207 Cylinder # 7 Injector Circuit Open/Shorted
P1208 Cylinder # 8 Injector Circuit Open/Shorted
P1221 Pedal Demand Sensor B Circuit Range/Performance
P1224 Electronic Throttle Control Position Error
P1226 Mechanical Guard Circuit Range/Performance
P1227 Mechanical Guard Circuit Low Input
P1228 Mechanical Guard Circuit High Input
P1229 Electronic Throttle Control Circuit
P1230 Fuel Pump Relay
P1235 VSV 1/2/3 Circuit Range/Performance - Read Our Article On Automotive Circuit Testing For Help With This Jaguar Check Engine Light Code
P1236 VSV 1 Circuit
P1237 VSV 2 Circuit
P1238 VSV 3 Circuit
P1240 Sensor Power Supply
P1241 Sensor Power Supply Low Input
P1242 Sensor Power Supply High Input
P1243 Analog Ground
P1245 Crank Signal Low Input
P1246 Crank Signal High Input
P1250 Throttle Valve Spring
P1251 Throttle Position
P1252 VSV Stuck On VA/VV
P1253 VSV Stuck On VR
P1260 Theft Detected, Vehicle Immobilized
P1313 Misfire Rate Catalyst Damage Fault - Bank 1
P1314 Misfire Rate Catalyst Damage Fault - Bank 2
P1315 Persistent Misfire
P1316 Misfire Rate Exceeds Emissions
P1336 Crankshaft/Camshaft Sensor Range/Performance
P1340 Camshaft Position Sensor B Circuit - Read Our Article On Automotive Circuit Testing For Help With This Jaguar Check Engine Light Code
P1341 Camshaft Position Sensor B Circuit Range/Performance
P1361 Ignition Coil, Cylinder # 1, No Activation
P1362 Ignition Coil, Cylinder # 2, No Activation
P1363 Ignition Coil, Cylinder # 3, No Activation
P1364 Ignition Coil, Cylinder # 4, No Activation
P1365 Ignition Coil, Cylinder # 5, No Activation
P1366 Ignition Coil, Cylinder # 6, No Activation
P1367 Ignition System Failure Group 1
P1368 Ignition System Failure Group 2
P1370 Insufficient RPM Increase During Spark Test
P1371 Ignition Coil - Cylinder 1 - Early Activation Fault
P1372 Ignition Coil - Cylinder 2 - Early Activation Fault
P1373 Ignition Coil - Cylinder 3 - Early Activation Fault
P1374 Ignition Coil - Cylinder 4 - Early Activation Fault
P1375 Ignition Coil - Cylinder 5 - Early Activation Fault
P1376 Ignition Coil - Cylinder 6 - Early Activation Fault
P1384 Variable Valve Timing Solenoid A Circuit - Read Our Article On Automotive Circuit Testing For Help With This Jaguar Check Engine Light Code
P1392 Variable Valve Timing Solenoid A Circuit Low Input
P1393 Variable Valve Timing Solenoid A Circuit High Input
P1396 Variable Valve Timing Solenoid B Circuit
P1397 Variable Valve Timing Solenoid B Circuit Low Input
P1398 Variable Valve Timing Solenoid B Circuit High Input
P1400 Exhaust Gas Recirculation Valve Postion Control
P1401 Exhasut Gas Recirculation Valve Postion Circuit
P1408 Exhaust Gas Recirculation Thermister
P1409 Exhaust Gas Recirculation Valve Circuit - Read Our Article on EGR Valve Codes For Help With This Jaguar Check Engine Light Code
P1440 Purge Valve Stuck Open
P1441 ELC System 1
P1447 ELC System Closure Valve Flow
P1448 ELC System 2
P1453 Fuel Tank Pressure Relief Valve Malfunction
P1454 Evaporative Emission Control System Vacuum Test
P1475 Fan Relay (Low) Circuit
P1476 Fan Relay (High) Circuit
P1508 Idle Air Control Circuit Open
P1509 Idle Air Control Circuit Shorted
P1514 High Load Neutral/Drive Fault
P1516 Gear Change Neutral/Drive Fault
P1517 Cranking Neutral/Drive Fault
P1534 Restraint Deployment Indicator Circuit
P1565 Speed Control Command Switch Out Of Range High
P1566 Speed Control Command Switch Out Range Low
P1567 Speed Control Output Circuit - Read Our Article On Automotive Circuit Testing For Help With This Jaguar Check Engine Light Code
P1568 Speed Control Unable To Hold Speed
P1571 Brake Switch
P1582 Electronic Throttle Monitor Data Available
P1600 Loss Of Kam Power, Circuit Open
P1603 EEPROM Malfunction
P1605 Keep Alive Memory Test Failure
P1606 ECM Control Relay Output Circuit
P1607 MIL Output Circuit
P1608 Watchdog Malfunction
P1609 Internal Control Module CPU To CPU Communication Failure
P1611 Throttle Target Malfunction 1
P1612 Throttle Offset Malfunction
P1637 CAN Link ECM/ABS Control Module Circuit/Network
P1638 CAN Link ECM/INSTM Circuit/Network
P1641 Fuel Pump Primary Circuit
P1642 CAN Link Circuit
P1643 CAN Link Engine Control Module/Transmission Control Module Circuit/Network
P1646 Linear O2 Sensor Control Chip (Bank 1)
P1647 Linear O2 Sensor Control Chip (Bank 2)
P1648 Knock Sensor Input Chip
P1696 CAN Link Engine Control Module/Cruise Control Module Circuit/Network
P1697 Cruise Control Distance-Control Input Circuit
P1700 Transmission Indeterminate Failure (Failed To Neutral)
P1720 Vehicle Speed ( Meter) Circuit
P1722 Stall Speed
P1726 Engine Overspeed
P1730 Gear Control Malfunction 2,3,5
P1731 Inconsistent Gear Ratio
P1734 Gear Control Malfunction
P1745 Pressure Regulator 1
P1746 Pressure Regulator 2
P1747 Pressure Regulator 3
P1748 Pressure Regulator 5
P1758 Pressure Solenoid Control System Incorrect Current
P1775 Transmission System MIL Fault
P1776 Ignition Retard Request Duration
P1777 Ignition Retard Request Circuit - Read Our Article On Automotive Circuit Testing For Help With This Jaguar Check Engine Light Code
P1778 Transmission Reverse I/P Circuit
P1779 Load Control
P1789 Ignition Supply Malfunction
P1790 Ignition Supply Malfunction
P1791 Ignition Supply Malfunction
P1792 Ignition Supply Malfunction
P1793 Ignition Supply Malfunction
P1794 Battery Voltage Circuit
P1795 Inconsistent CAN Level
P1796 CAN Controller Circuit (Bus Off)
P1797 CAN TCM/ECM Circuit Malfunction - Read Our Article On Automotive Circuit Testing For Help With This Jaguar Check Engine Light Code
P1798 CAN TCM/INST Circuit Malfunction
P1799 CAN TCM/ABS Circuit Malfunction
P1882 Engine Coolant Level Switch Circuit Short To Ground
P1111 System Pass
P1236 VSV 1 Circuit
P1237 VSV 2 Circuit
P1238 VSV 3 Circuit
P1243 Analog Ground
P1441 ELC System 1
P1448 ELC System 2
P1571 Brake Switch
P1722 Stall Speed
P1779 Load Control
The following 6 users liked this post by kthrash:
45Wheelgun (03-25-2011),
Al Theman (08-09-2011),
chadmc5c (03-29-2011),
DB6 (03-25-2011),
magmedia (02-07-2012),
and 1 others liked this post.
I would get the faults checked by the dealer or other shop, and not AutoZone(lol). Their "scan tool" may be "CAN" compatible, but it doesn't communicate with other control modules on the CAN network as say "IDS/SDD" would. Chances are you have a bad throttle body. But... The faults still need to be checked first.
My 2004 XJ8 (38,000 miles) did the same thing and I fixed it.
Here's what happened. I was going on a day trip on a Sat. and so the day before, I went to the car wash and they also did the under body wash. Saturday evening after the trip I stopped at my friend's house for a while and then headed home. After a short way I got all the symtoms that you did including the Messages. Mine did it several times and along with the P1111 (emissions stuff passed some tests) I got a P0121. A lot of people will run out and pay the bucks for a Throttle Body, but I did this first.
I removed the engine top cover ( four quick lock screws) oil cap slows you down; take it off, then put it back on. The first metal part on the engine after the MAP, which is after the air cleaner, is the Throttle Body. You will see a four wire plug connected to it. Push the lock in and pull the plug loose. Spray WD-40 onto and around the prongs that you now see. Then spray the inside of the plug to remove any moisture in it. Believe me , it gets in there. Connect and disconnect the plug several times to clean the connections. Put it back together and give her a test.
No more problems for over a month now.
![Icon Redcam](https://www.jaguarforums.com/forum/images/smilies/icon_redcam.gif)
The P0121 is not an uncommon problem with the xj, xk & s-type and I would strongly suggest checking the plugs first. Displacing the water with WD-40 was the right thing to do. My car I pulled the plug, cleaned it with CRC contact cleaned, replaced the contacts (TSB) and used Die-electric contact paste to displace any water from entering the plug again. You can read about it on my page TBoddy Hope this helps!
![Red face](https://www.jaguarforums.com/forum/images/icons/icon11.gif)
I was just doing a search on my 2004 xj8 with 116,000 miles and the same problem. The car runs mint otherwise, had it since 37,000, did all maint., etc. A week ago, she starts quitting for no reason, for seemingly no reason. Was about to replace all the oxygen sensors, when I found this thread. I went out and did the WD-40 thing, and so far, so good. Thanks!
Guest
Posts: n/a
Hello everyone. I'm new to this forum. I have a 1986 XJ6 and I have the same problem. It the engine just shuts off while driving. I noticed that the cars above were a lot newer than mine. Has anyone had this happen to them before with an 86 or knows where should I start to fix this problem. Anything would help. Thank you.
That same issue has happened several times on my '06. After great consternation, I discovered, much like some others here, that spraying CRC on the Mass Air sensor and into the throttle body, seems to clean off any 'gunk' that accumulates. I also spray the electric contacts with (I forget the name) the product designed to clean electric contacts.
This method resolves the issue, at least for 8 - 10 miles. It seems to me that as grime builds up, the computer gets a false readings. That may not be accurate, but certainly this solution solves the issue!
philwarner
12-06-2021 07:13 AM
NinoGrimace
08-26-2015 05:15 AM
