2004 XJ8 at local Junkyard
Old 01-18-2019 | 03:37 PM
annamiata's Avatar
Default 2004 XJ8 at local Junkyard
This is the first time a junk 2004 Jaguar XJ8 shown up in my local junk yard. Its a self pull a part. I am planning to pull the air shocks ($15.00 each) , pump, couple O2 sensor ($10.00 each), couple coils ($10.00 each). What other rare parts should I pull?
Old 01-18-2019 | 11:45 PM
abonano's Avatar
Alternator, air compressor.
Old 01-19-2019 | 09:01 AM
Wingrider's Avatar
Starter, sensors, wiring harnesses with the components that are pulled.
If you have the money, and space, the whole vehicle as a parts car.
Old 01-19-2019 | 09:53 AM
Brutal's Avatar
Seats headliner, hood trunk, doors, grill headlights differential, trans engine, coolant bottle, side markers, center console electronic stack, doors, did i miss something
Old 01-19-2019 | 11:19 AM
Partick the Cat's Avatar
Window regulators.
Old 01-19-2019 | 01:40 PM
genec's Avatar
Sun visors, if they are in good condition (I'ii take the drivers side thank you ) As many of those little "push pins" in the engine compartment as you can find. Cigar lighters. Spare change under the seats.
Old 01-19-2019 | 03:09 PM
abonano's Avatar
Shifter assembly
Old 01-20-2019 | 01:13 AM
Mark in Maine's Avatar
And on, and on and on. Strip everything electric/electronic. Skip the bushings.
Old 01-20-2019 | 06:59 PM
Rancheroguy's Avatar
Check the headlights. If they are Xenon grab them. They are worth a lot. Get the connections also. I wish I could find one here to strip. You are lucky.
Old 01-20-2019 | 07:29 PM
Wingrider's Avatar
How much for the car????
Old 01-21-2019 | 10:28 AM
annamiata's Avatar
I was there last Sunday to remove parts. I could not go Saturday and someone beat to it and took bunch of parts including side mirrors, abs brake pump, driver head light, driver fender. The car was involved in a passenger side accident. I was able to purchase the air compressor, complete throttle body, three coils, three injectors, thermostat housing, coolant heat pump, air flow sensor, wheel lugs, and three or four dozen of nuts and bolts for less than $100.00. I could not remove bottom bolts from the shocks. I will come back with impact gun, blow torch to unfreeze the bolt.
They do not sell whole car.
annamiata
XJ XJ12 ( X305 )
12-07-2018 03:20 AM
tom999w
10-22-2018 10:47 PM
TnPainter
05-07-2012 05:57 PM
junkyard jag
05-20-2011 10:57 AM
ac427
08-24-2010 11:10 AM
