2004 XJ8 Melt Down?
2004 XJ8 Melt Down?
Hello All.
I have an 04 XJ8, and I am suddenly having intermittent issues. ABS and DSC unavailable, but if I restart it, it goes away. Today the radio started changing stations, but the display stayed the same. Turned off the radio and turned it back on, problem gone.
While driving with the cruise on, the cruise shut off and ABS and DSC lights came on. Parked and restarted after exiting the highway. Again everything reset. Got back on road and went a quarter mile, ABS and DSC lights come on, then the transmission bangs and the Gearbox Fault light comes on. Restart, same result. Everything resets, then ABS and DSC light stay on but not Gearbox fault. Seems like it must be electrical, as it is intermittent. Gearbox fault always follows abs and DSC faults, and then goes away upon restart. Sometimes ok for days or weeks, sometimes just a few minutes. Where should I start? I like to try to fix things myself.....
Hi Vince and welcome to the forum. I have moved your post from the XK8/XKR section to the XJ (X350/358) section for your specific model.
When you get a moment, please go to the new member area and post an intro New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum
Thanks SaturnV. The bang was a downshift, I believe. The fluid level is good, and after a restart, operates as normal, only after the ABS and DSC light trips, does anything ever happen. The trans seems to go into limp mode until the car is restarted, which is why I think it is electrical.
Things seem to have gone from bad to worse. I checked the battery terminals, which seemed a little dirty. Cleaned them up. Started the car and drove it, and all seemed fine. Came across an icy patch, stepped on the gas and the traction control worked fine. Stepped on the brakes, ABS worked as well. Went another hundred yards or so, and all the lights came back on, then the gearbox fault tripped as well. Now it is resetting on restart and then immediately tripping the gearbox fault, and now the check engine light is on too. Shifts badly out of first, then goes into limp mode. Makes an odd noise, kind of like an old air pump for emissions control on an '80s Dodge. Trans does not slip at all in limp mode. I am in big trouble now? Does disconnecting the battery have any weird affect? I seem to recall having an abs issue this past summer, disconnecting the battery and then having some weird check engine lights, low coolant warning, etc.
Autozone will check the battery for free and will probably hold a replacement battery in stock.
The XJ8 is a little fussy about ODB2 readers too by all accounts and some are not compatible with the car. A list of the compatible ones are here :
https://www.jaguarforums.com/forum/g...oved-**-33347/
When disconnecting the battery for any period of time you have to reconnect and follow a specific sequence to get the Engine management system working correctly. The sequence is available on the forum. I will see if I can find it.
Many excellent suggestions so far. 2 things I would also check.
The alternator, see what voltage you are getting at the battery when the car is running.
Also check the ground points in and around the engine bay for loose or dirty connections.
Agree with most though, get the battery checked first or at least make sure you have a fully charged one in the car.
Hope this helps,
Hope this helps,
I had most of your gremlins plus my glove box and fuel door would open every time I started the car. I had the battery tested, and they said it was ok, but could use a recharge. Based on my reading on this forum, I decided to just replace the battery. All of my gremlins are gone.
Start with a new battery.
Ok, so here is the skinny. The shop cleared the codes, and recommended I have the plugs and all 8 coil pack replaced, replace the inertia switch, and replace the throttle body. He cleaned the sensors at the wheels, and I have had no further issues with ABS or DSC lights. I have had no issues at all, having done none of the recommended services. I did replace the battery, as many suggested, and was glad I did, as it was -4F this morning. The car started and stalled twice, but once warmed ran fine. I am thinking of having the throttle body and the inertia switch done, then doing the plugs myself when it warms up. I cannot imagine it needing all coil packs replaced.....thoughts? Thanks again to everyone who gave me advice. Much appreciated!
It's hard to see how all the coils or indeed all the plugs could go bad at once. If it runs apparently OK then I'd get a cheap OBD2 tool with live data and check first for codes then that all sensors (well, those you can figure out!) have plausible values and lastly the fuel trims (LTFTs). They're very affordable tools and work on other cars.
If the plugs are due, I'd change them of course.
You might re-do grounds (I'd say battery terminals but you've done those).
If nothing found, I'd wait and see. You now have the obvious tool should it act up.
