2004 XJ8 parking lockout module - RESOLVED
Old 10-18-2021 | 10:18 PM
romroc's Avatar
Default 2004 XJ8 parking lockout module - RESOLVED
What is the part no. for xj8 parking/ignition lockout module? Due to sunroof seal failure, module was damaged. Where is module located? Also, module prevents key removal, so it gets complicated. If it was me I would have waterproofed all electronics to prevent these issues. As it stands, car is in neutral with key in key location #1 and not removeable. Battery is disconnected. Very sad state of affairs. Module part number and location urgently requested. HELP!
Note: key#1 is "accessory."
Last edited by GGG; 10-19-2021 at 11:02 AM. Reason: Add "RESOLVED" to thread title
Old 10-19-2021 | 06:04 AM
flatsix's Avatar
There is no parking ignition lockout module on these cars. Three different control units are involved in the process of key transponder recognition and ignition lock release. The vehicle should first be checked with original OBD equipment to get a clue.
What makes you think it is water damage?
Fritz
Old 10-19-2021 | 09:10 AM
OldKarz's Avatar
With foot on brake you should be able to move to Park position. Then if you move the lever left you should hear the switch indicate moving from Park. If the switch can be heard you would next check that the solenoid in the J-Gate is moving. Both of these need to work to remove key.
Old 10-19-2021 | 09:39 AM
romroc's Avatar
Car is in a skilled jag shop. Got out of park drove there. Sunroof caused problem, bad seals. CANBUS got wet.
Old 10-19-2021 | 02:56 PM
jackra_1's Avatar
Bad seals or blocked drain tubes? I would bet the latter.
Old 10-19-2021 | 07:02 PM
romroc's Avatar
thnks to all, will keep posting. Very nice limp to shop!
03xk8
02-23-2021 08:24 AM
romroc
09-18-2020 05:00 PM
Roc3207
09-11-2017 06:17 PM
blipner
08-02-2009 05:35 PM
Quick Reply: 2004 XJ8 parking lockout module - RESOLVED
