2004 XJ8 passenger window problem from drivers door
Hello Everyone, new member and extremely grateful for whatever advice you can offer me on this one.
My front passenger window will only go down from the drivers door switch unit. Press switch down - it goes down. Press switch up - it goes DOWN!
Tried window reset procedures and tried new switch pack off eBay, same fault.
Global down and global up work from remote and window works normally from passenger door switch.
Any advice please?
Any advice please?
Hi Peter,
For some reason you are displaying your vehicle spec twice, you will get there!!
Re your door, have you tried to press lock continually when the window is open?
I am sure you have the windows closing on feature with your keys so this may help?
Ty this, I apologise if you've read it?
https://www.jaguarforums.com/forum/x...09-vdp-100976/
Or this one:
https://www.jaguarforums.com/forum/x...windows-99549/
Good luck, Stu
Or this one:
Good luck, Stu
Last edited by Stuart Beattie; 01-29-2014 at 05:09 AM. Reason: including other link
Hi Peter,
Or this one:
Good luck, Stu
Or this one:
Good luck, Stu
I have tried to retrain the windows as described in these links to no effect.
Not sure what you mean by press lock continually when window is open. If you mean hold the up button up when the window is open then yes I have tried that. The only way to get it up is from the global remote all up from the fob or from the passenger door switch.
Thanks for the thought.
Peter
Hi and I hope yer lum is reeking fine?
I understand better now, what you are referring too by global remote is (auto closure: sunroof, windows etc, and locking ALL through the fob, holding lock button) and I take it they are working? just the passenger window doesn't go up with the door switch?
Okay Peter, we'll get there and I'll have another look/search for you.
For what its worth, have you tried a good squirt of WD40 in the door locking area or a smidgeon of dry silicon?
Hang cool, Stu
Hang cool, Stu
PeterXJ8 (01-29-2014)
As you have eliminated the Driver's Door Switchpack by substitution, it appears there could be a door harness or Driver Door Module issue.
To troubleshoot this you will need to Fig 14.1 in the XJ 2003.5 Model Year Electrical Guide:
As a new member, you don't have sufficient posts to download PDF's from the forum so I have put this document on my MediaFire account. You can download it (free) by following this link:
http://www.mediafire.com/view/72ql1q...al%20Guide.pdf
It's a 5mB download so could take some time if you have a slow internet connection.
Attachment 70639
Attachment 70639
Hang cool, Stu
Hang cool, Stu
Hi Peter
I have the same problem but this time with the nearside rear door , works fine on
the door switch but on the drivers switchpack down is down and up is down . I have
also tried a new switch for e bay with no luck . Did you ever cure the problem ?
Any info would be appreciated
Steve
Steve
Hi Peter
Steve
Steve
Hi guys,
I know this post is ancient, but I have the very same problem, but with the offside rear door, rear door switch works as it should, global closing and opening works as it should, drivers door switch pack works as it should, with the exception of the offside rear window which, goes down with a down press, and down with an up press, I have also replaced the drivers door switch pack and the same fault remains. I think that maybe I will swap the rear door switch just as a, "what if", but I really don't see that doing anything.
I have just downloaded the electrical guide that GGG put up, thanks for that, although mine is a 2006 model, but it might lead me somewhere.
hafren
08-30-2023 03:42 PM
philwarner
12-06-2021 07:13 AM
