2004 XJ8 Replace front left lower wishbone arm
I recently had my 2004 XJ8 in for service, the said they recommended that I Replace right rear sway-bar link (Found right rear sway-bar
link worn/loose).
The cost for this was just under $3000.00. Are these items that I need to replace or are they ones that may degrade ride and tire wear over time and need not be replaced. I love the car, but this is a lot to spend if not really necessary.
Any experience or advice is most appreciated. Thanks.
link worn/loose).
Replace left rear sway-bar link (Found left rear sway-bar link
worn/loose)Replace front left lower wishbone arm (Found bushing leak
from front wishbone arm)Replace front right lower wishbone arm (Found bushing leak
from front wishbone arm).The cost for this was just under $3000.00. Are these items that I need to replace or are they ones that may degrade ride and tire wear over time and need not be replaced. I love the car, but this is a lot to spend if not really necessary.
My Jag is about the same age as yours and I have never replaced any suspension parts.
Are there any clunks or knocking noises or squeaks when you drive it? Wishbone bushes squeak when they fail.Any problems with uneven tyre wear?
I think they have shot themselves in the foot! There is nothing to leak in the wishbone bushes as far as I know! 3000 USD has got to be a rip off! Take it elsewhere for a second opinion.
Ask yourself what can happen if I do nothing? That's cheap!
Billsblue73 (10-10-2012)
One of the front bushes in the lower wishbone arm is a 'Hydrabush'. One of them leaked on my X350 (2004/52,000 miles) so I have had both replaced along with the D shaped sway bar bushes and one of the lower shock bushes. The rear end has had a fair bit replaced as well.
You should be able to get the items mentioned replaced for well under $1,000 and probably a lot less.
More info on sourcing the wishbone bush here:
The definitive wishbone bush thread
Well, my front suspension started squeaking today. It squeaks if I manually bounce eeither front fender, but no noise form bouncing the rears.
Last year, I replaced both front air shocks and lower control arms. It seems strange to me that both upper A arm bushings would start squeaking at the same time. This leads me to suspect the issue is more likelt a sway arm (stabilizer bar) bushing. Do you guys have any other theories?
philwarner
12-06-2021 07:13 AM
Fraser Mitchell
10-01-2015 04:06 AM
