2004 XJ8 sagging headliner
Does anyone know how to re-adhere the headliner in the rear upper post area? Also, the headliner has detached from the moon roof slider. I used a mudknife to re-stretch it, but have not tried to glue it back.
The rear portion has simply sagged where the post meets the roof. What technique would you suggest...
BigCat3153 (08-29-2011)
I have read a lot of posts on sagging headliners on this forum which is mostly US guys posting. Is it an issue just in the US, and maybe just the sunshine states, or where it gets really hot ? Reason I ask is because it is not a problem here in the UK where we have cold and wet summers like this and last years, (and the previous 10 for that matter !!)
Sagging headliners
I have a 2000 XJ Vanden Plas in sunny and hot Florida. The headliner started sagging in the back. The problem is the foam backing the material is attached to starts to crumble from the heat. There is no repair that will work. It has to be replaced. I simply looked in the local telephone directory and had a guy come to my car and place the entire headliner in about an hour for $100.00. It looks great and totally restored. Good luck.
That's way off the mark! Most fabric, boat, automotive custom & interior shops should be able to get it done.
BigCat3153 (09-07-2011)
Guy-Pierre Boucher
09-16-2015 05:55 PM
