2004 XJ8 Sitting too low
![Question](https://www.jaguarforums.com/forum/images/icons/icon5.gif)
My 04 xj8 is sitting too low.. with no dashboard message ( Car too Low) (air Suspension) none of that..i think front and rear are both sitting too low..rear definitely is. Not down where it scrapes wheel wells. Driveable but scrapes on speedbumps or driveway.I recently had it hauled on a flatbed due to needing a new fuel pump and it was put on a lift at repair shop when changing oil.I didn't seem to have any height issues until after that trip. Coincidence ? Same height parked or running.Thanks in advance for any help.
Jag Brent (09-14-2016)
Welcome to the forum Jag Brent,
I've deleted your identical post from General Tech Help. This is the place to post technical questions about your model.
You might check the lower control arms for damage to the ride height sensors if the flatbed tow truck used chains/straps to pull/secure the car.
A bent or disconnected sensor will cause problems. The suspension control module cannot control the height if it does not get INPUT.
2004 to VIN (G26871) should have BOTH front control arms with sensors and only one (left) subsequent. (see TSB XJ204-05)
bob
bob
powerhouse
08-30-2016 01:23 PM
