2004 XJ8 Suspension
My front end has been down for a week, I ordered Arnott compressor and installed. Car would not raise, pump would run and shutoff. Also had trans leak after getting trans fluid/pan. Took it to jag cert, mech today around 1pm, told them to ck electrical sleeve, and that I had replaced the pump. They called @ 4pm and said it was fixed. I was stunned..they said they cleared the puter and it raised. Also put new o-ring on plug below sleeve. Told me they cleaned everything up nice and said...@ the first sign of fluid leak, bring in, we fix. No charge for today.....very nice. I have spent about 1,500$ there in repairs in the recent past. They didnt give me paperwork, maybe forgot, I wanted to see if the codes backed up the compressor R&R. Will keep posted on any new developments
Dak888
Dak888
I've got the same sounding problem on my 2005 VDP, over sharper bumps the front end hops around and transmits vibration into the steering. Some have said it's the steering rack. Someone else that it's a component tolerance "stacking" problem, from multiple components being on the same end of their tolerances. Another suggested bushings (but the bushings have been replaced).
To me it feels like bad shocks. I've had bad shocks in other cars that behaved similarly.
Too many people are describing similar sounding symptoms. There's a systematic problem but nobody seems to have nailed a common cause.
Guy-Pierre Boucher
09-16-2015 05:55 PM
