2004 XJ8 Transmission Question
pan with filter and 7 liter/ quart of zf lifeguard 6 oil is the way to go . But the car has to be leveled, filled till overflowing then start engine and go throuh all the positions of the gear lever and fill up some more until oil has min 40 degrees celcius 100fahrenheit fill up till it overfloats . Then close.
The ZF is the same but there might be a few "gotchas" in pulling out the box if it needs a major fix.
Plus if something Jag specific gets broken or needs renewal how do you get the part ?
If the problem is only in the mechatronic or something that can be fixed with the box still in the car there is no drama at all.
You have to find a transmission shop familiar with ZF and who are not lazy or already well on the way to being millionaires.
