2004 XJ8 turn signal problems
I recently bought a 2004 xj8 in excellent condition, there is on issue though. When I put on my left blinker the rear right turn signal, brake light, license plate light, and even the light in the trunk flash. I'm assuming it's something to do with the fuse box because removing the 5 amp left rear light cluster fuse does not turn off the lights but removing the right light cluster fuse turns off the right lights. Any suggestions or anything I should test before going and buying a new fuse box?
chaby88
07-09-2021 06:00 PM
EFlavio
06-05-2013 04:22 AM
