2004 xj8 won't unlock from inside
This has happened very occasionally on my Jag and I leant over to pull the passenger
door handle when the door unlocked.
The other option is to press the unlock button on the central console.
I can only imagine that there is a fault with the actuator but only when you use the door handle.
Do you have to use the key fob every time you want to open the driver's door?
Door actuators often fail to work but your type of failure is unusual.
Guy-Pierre Boucher
09-16-2015 05:55 PM
