2004 XJR engine compartment fuel leak ..Please help me ID this part.
2004 XJR driver's side FPR, or FP sensor? just below the intercooler.
Hey all. thankfully she didn't catch on fire, but I can't quite make out what this line and component actually are. It drips while running and for a few min after the engine is shut off. My guess is the fuel pressure regulator, fuel pressure sensor, or some kind of evap return component. no error codes of any kind. I dodged a bullet by catching it when I did! Praise and thanks to the Jag gods! I've had her 9.5 years and she has never left me stranded. This is good because a)the local shops are not very competent on these. and b) I don't drive what I don't wrench on.
1) Anyone know the part?
2) Anyone dealt with this before?
3) It's leaking as if there should be a hose clamp on it. looks like the black plastic part at the end toward the engine was a ratchet clamp, but that's crazy, right?
Excellent, thank you Sir! So I see how to remove that clip from the underside now. Seems simple enough. Trying to find how far back this part runs and how to remove other end. Also, not having much luck finding the part new or used......
Have yet to see a Ford part looks like this....these pics are from a listing on an S type,sadly not an R....but it looks to be same quick release fitting and that's a start. Hate to "hack" together a high pressure fuel fitting but desperate times.....anyone else have any suggestions?
i’m saying you use the ford quick connect tool to remove it
again the fuel feed pipe has been unavailable for probably 10+ years
go call any junkyard that has an x350 sc in stock and ask them if they can pull the line that goes from the rail to the wheel well
next question, anyone know what this part is? Same part number for a diesel unit as on my rail. DOES NOT come on the v6 S type fuel pipe. My guess is a damper. Wondering how necessary this part is as it introduces two possible leak points when trying to put together a replacement line incorporating it with clamps of some sort. Definitely isn't used on the later XF/XJs with 5 l supercharged engine.... Seems to be an 03 through 05 model year type S through XJ variant thing only
Update! at least have IDd what kind of fuel line connector it is. According to Napa it is a springlock fuel line connector. don't know if this is the right size but definitely on the right track...
Ok, so after seeing I'd have to pull the intercooler to be able to get quick disconnect tool access, I decided to follow the sage words of Xalty and did indeed go the "hack something together" route However, I think It is the best repair possible.
I did some research on nylon fuel line. It's NOT easy to bend without collapsing. It's not very forgiving either. You have to heat it up In order to make it semi malleable. But the moment you go too hot it burns through. Had the compounding issue of fitting it to two fixed barbs making a heat gun an unacceptable risk around open fuel lines. That's when a very hot cup of microwaved water comes into play.
The real trick is to bend the section using a long spring inside acting as an inner mandrel. In this case I cut off the end of one of those cheap mechanic parts grapplers You can get for like 6 bucks at harbor freight. Bend the spring, apply heat gun. Came out reasonably decent. One on left is mine. One on right was what I was trying to mimic. Three dimensional bends are a bit trickier.
After that you want to get it ready for the barbs. Best way I found was using one of the spring lock replacements I listed in previous post. Holding that in place with vise grips. Heating it up periodically while stretching the two ends over it. This was the hardest part.
The best clamps to use are single ear/ one use hose clamps that are pretty much designed for fuel lines. The trick to using those is having access for the ear clamp pliers. I had to get real creative on the engine side....
Overall it looks pretty good and feels pretty solid. That said , I'm always going.to be checking it every time I open the hood.
Hope this helps someone who finds themselves in the same spot and saves you some time!
