2004 XJR Front Wheel Bearings Replacement
Old 10-03-2014 | 08:26 PM
FreakingAwesomeJag's Avatar
Default 2004 XJR Front Wheel Bearings Replacement
Hi all,
I need to replace the front wheel bearings in a bad way.
Two quick questions. 1.) The job looks straightforward. Any trips or tips? I could really use any help here.
2.) Was going to get the full assembly (135k) and replace the whole thing. Cost is about 120 USD each side. TIMKEN and BECK ARNLEY parts available.... Any favorite MFG for good fitment etc? Thoughts?
Thanks all, always appreciate the feedback here !!!
Kevin
Old 10-03-2014 | 08:45 PM
Don B's Avatar
Hi Kevin,
As always, the forum Search function is your friend. See this active thread for a lot of useful info:
https://www.jaguarforums.com/forum/x...earings-86285/
Cheers,
Don
AD2014 (10-05-2014)
Old 10-04-2014 | 12:54 PM
Default Thanks Don
Let me tell you bro, I was looking. I think my Friday evening search skills were garbage from a long week of working. Thanks for the direction. The link was just what the Dr ordered.
Ordered parts and will tear down next week. Love this site man!!
Thanks again
Old 08-30-2015 | 10:18 AM
ryejag's Avatar
any issue getting the old bearings out> Torque for the bolts holding the bearing flange?
thanks
RyeJag
Old 08-30-2015 | 10:56 AM
Torrid's Avatar
It's simple enough. Breaker bar to knock the four bolts loose that hold the hub on. That's the hardest part.
I'd double check, but think torque spec was 65 ft/lbs.
BrentGardner
28
04-26-2024 04:08 AM
Doberman_Fan
22
12-24-2019 07:21 AM
Paradigm
06-15-2019 06:59 AM
Bernie Posadas
09-03-2015 09:06 PM
aquifer
08-29-2015 05:54 PM
Quick Reply: 2004 XJR Front Wheel Bearings Replacement
