2004 XJR--Info on purchase of used module.
My headlights, wipers, windows, glove compartment, and fuel doors buttons are not functioning. I was hoping that it was a blown fuse. However, the mechanic stated that the module needed to be replaced. Mechanic also stated that Jaguar no longer sells new modules for my vehicle and that cannot guarantee that a used module will work. If used module does not work, I'm still out of pocket for module and labor costs. Anyone ever purchased used module?
Jaguar XK Series: Jaguar Used Parts, Auto Body Supplies, Salvage Car Wrecking Junk Yard ...... also XJ8's and R models. Out towards their last 5+ pages they list a ton of modules.
Sean W (09-11-2017)
EDIT - original post a complete miss on my part. I started reading the wiring diagrams from the end point and didn't get to the FEM. Basically I started backwards and stopped too early.
https://www.jaguarforums.com/forum/x...advice-187787/
thank you Bob.
thank you Bob.
Last edited by Sean W; 09-11-2017 at 05:35 PM. Reason: incorrect feedback sent initially
I believe the FEM is NLA. You can call a local dealer and inquire if that is the module that the local mechanic thinks is the fault.
Configuring modules to these cars can be 'tricky'. Be sure you understand what modules need configuration and make sure you understand the VID block.
ADMIN TSB 1-186 has info before you start something that requires tools you don't have.
There are discussions on this forum about configuring modules, both successes and failures.
bob
bob
Sean W (09-11-2017)
