2004 XJR Motive Power Brake Bleeder
I have the Motive Power Brake Bleeder that I use on my GM truck and Suburban. If anyone has used this on a X350, can you post which adapter you used for the brake fluid reservoir? Looking at their website it is either not obvious or I am not seeing it.
Motive Products #1 Selling DIY Brake Bleeder
Thanx!
Thanx!
Lagonia,
You may find this info from the Motive Power Bleeder website.
"European Makes -
Nearly every European made car can use the 1100 and 1109 caps that are included in the 0100 and 0109 kits. These caps are female threaded caps and have an inner diameter at the threads of 45mm. BMW, Porsche, Saab, Volvo, VW (except air cooled) have used this type of cap since the late 1950s. Most other european cars also use this cap with some exceptions. Ferrari on some models and years will use a slightly smaller cap that is 42mm inner diameter. If you have a European made cars with a female threaded cap will more than likely use the 1100 and 1109 caps, but please check the inner diameter of the cap to be sure."
I have one of the listed kits and I have used mine on my Volvo 850 and it threads easily on the X350. I haven't actually bled the system, as I'm waiting for spring. I'm confident it will work.
Hope this helps.
Regards,
Ron D'Amico
"European Makes -
Hope this helps.
Regards,
Ron D'Amico
Lagonia (02-06-2014)
