2004 XJR Multi function switch replacement
Hi all. I need some advice and help!
I have the blinking headlights problem (intermittent of course). I have cured this in short order in the past on other Non Jag vehicles by replacing the multifunction switch.
On other vehicles you remove the cover around the tilt wheel and the switch is usually easily removable. I got a replacement from a wrecking yard. Elite Auto Parts (great spot 818-767-0445) and the multifunction is a one piece set up that shows you have to remove the steering wheel to install. Getting ready to tackle that project this weekend and was hunting for some tips and tricks. I would hate to break a clip i did not need to or mess something up.
Any advise or how too's are welcomed. Thanks.
Ooooh ... with headlight blinking probs (not uncommon on x350s) ... the multi function switch is the very last thing I'd look at ...
1. Check the earth (ground) points of the headlamp units; they earth to a stud somewhere on the frame behind the front bumper (fender) this is a widely recognised fault point on x350s. Others who been there, done it and got the T-shirt will tell you exactly where that is.
2. If the headlights both sides blink together (ie synchronised) then check the continuity of the signal wire from the Front Electronic Module (FEM) to the Front Fuse Box (I speak from experience) the wiring loom when it comes over to the RHS of the car runs inside the front wheel arch, behind the liner, and is subject to water damage.
3. If the R & L sides don't blink together, and it's the dip beams, and they're HID lamps, and the earths (1 above) are okay ... then ... change the 'burner' (that will cost money ) going on-and-off-and-back-on-again-etc-etc is a sign a burner is on its last legs.
If they don't blink together you can say for certain that it IS NOT ...
- the multi func s/w (that has single control wire to the 'whatever' unit, which 'talks' to the FEM (digitally) via CANBUS;
- nor the FEM;
- nor a relay in the F Fuse Box (one relay does both sides).
That's my sixpence worth .. others who've done the earth thing will doubtless give theirs
cheers just now
Dave in Gloucestershire UK
- nor the FEM;
cheers just now
A new steering binnacle switch cured my flickering headlamps at night, and nav. display swapping between day and night settings, (and I suspect headlights switching on and off in daylight).
I decided to act when, on a cold and very dark night on a twisty road here in Cheshire, I lost all headlamps for about 2 seconds. £125 well spent. These switches are a well known failure point.
Patrick thanks for the response and all the information. I am not a fan of electrical and tracking down all the various issues, and given that I have had repeated sucess in various vehicles replacing the multi function switch, I got the part as did Fraser.
Fraser, did you replace the part?
That leads back to my original question/Tips and tricks...... How do you remove the steering wheel ?
Anyone have any step by steps for steering wheel removal?
Let me know and thanks
Paradigm
06-15-2019 05:59 AM
