2004 xjr no response from key turning (won't start)
So i got into an accident today in my 04 xjr. THere are a lot of deer in my area and one popped up around a blind turn, so avoiding hitting the deer, i ended up hitting a light pole. The damage is on the front end and the drivers side fender. Air suspension is out and completely flat but almost certain that the cause is the air compressor, and now Car won't start. It will not attempt to crank, when i flip the key to cranking position, it does nothing. I am really hoping there is an inertia switch somewhere on these cars and that is the problem. The code i am getting is reading ignition failure. Anybody heard of this before? I thought it was a security feature, I tried locking/unlocking doors from the outside, that didn't do much. Really want to fix all the mechanicals myself and then get it over to the shop for the body work asap. ANy help is appreciated. Thanks!
You need to check electric supply to engine-related components, and this mostly means the fuses. Also write down a list of what works and what doesn't then relate it to fuses. Check you have done inertia reset correctly. An AVO metre should show nil resistance between the two electrical contacts.
Donzi
09-07-2015 12:06 PM
1964Daimler
09-02-2015 11:41 PM
Andrew McVey
16
08-27-2015 07:21 PM
