2004 XJR - Parkprake fault and other maladies
I just came back from a 5 day vacation (the Jag was in the garage all this time) and when I entered the garage I noticed the right rear side marker light was on! "Odd" I thought.
I immediately grabbed the keys and turned the car on - this is what I found out:
- Car cranked and started normally
- Park brake fault and amber light came on on the dash board. The EPB appears to be working correctly
- *ALL* the rear lights (including the license plate lights) do not come on when the should except the right rear marker light
- The trunk switch does not work.
- The fuel sender registers empty even though it is not.
- When I turn the car off and remove the key, the rear right marker light remains on.
Battery is 4 years old in October. Do not have any time to do any further troubleshooting tonight but I thought I would throw this out there to see if anyone else had similar problems. Tomorrow after work I shall test the battery first to determine the next steps.
Shoot, I had to test it *now* (!) since that would have prevented me from achieving a good night's sleep:
Disconnected the battery and used a digital battery analyzer:
- Battery is 100% charged for its 850 CCA capacity.
- Battery voltage is 12.56 volts
- Battery resistance is 3.1 mOhms
I shorted the ground and positive cables and reconnected the battery.
Problem disappeared - all the rear lights are back on (including *both* rear marker lamps), the fuel sender gauge is working, park brake fault disappeared.
If there's an explanation that makes sense, please share!
![Icon Hide](https://www.jaguarforums.com/forum/images/smilies/icon_hide.gif)
I burned a watch on my wrist as an 18-old... it melted... smelled awful - that's my skin.
Always remove the ground from the battery first (and it's not always the - minus, in older vehicles there are also + positive grounded electric systems, mind you) if you are moving around with anything under the hood or near battery.
Yes, the well-tested full reset goes like this: remove the battery, then short circuit (touch together) the CAR-end battery cables in the trunk. Apparently this empties the capacitors (condensers) etc that hold voltage in the finer electronics.
