2004 XJR Quit shifting - P0783, P0730
Got in the car and started driving home tonight when I realized that the message "Gearbox Fault" started flashing. On the highway I also realized the tranny would not shift from either the 1st or 2nd gear. I tried to shift it manually but no go. I drove it slow through back roads and on a stop sign I simply turned off the car and re-started it. The problem went away.
When I got home I hooked my AutoEnginuity software and pull two codes from the Transmission Control Module:
- P0783 - 3-4 Shift Maufunction
- P0730 - Incorrect gear ratio.
Another possibly related symptom that I have with the car is that the 1 - 2 gear shift sometimes is pretty hard!
Now, some more details:
I did a tranny service about 200 miles ago. I replaced the pan and followed the published instructions to the tee (in terms of filling the tranny at the right temperature and waiting until it drips. I used ZF-Lifeguard fluid BUT it only took 3 quarts.
So, could the tranny fluid be low and cause this issue? If not, what else should I worry about? I will put it on the lift this weekend, check the fluid and respond back. In the mean time, any thoughts will be appreciated.
Sounds like you need a TCM software reload,(aka "reflash") and reset to cater for slight wear in the gearbox. This should correct your problems. However when you did the fluid, did you check the enry point for the connection to the TCM ? This can start to leak fluid which gets onto he pins and gives false info to the TCM, which is in the gearbox
I checked the fluid level again this morning and it was perfect. So, no problem there. I did attempt to reset the TCM adaptations but even though I have the Jaguar enhanced module for the AutoEnginuity software, it returned an error saying that the command is not supported on my vehicle.
I did clear all the codes but the P0730 evidently does not get cleared. I do not know what the deelio is there.
I'll drive it next week and see what happens until I figure out a way to reset the TCM.
Indeed! I just talked to a mechanic today and really feel embarrassed. The car was NOT running when I filled the tranny cavity while it is running and the temperature is between 30 - 40c. Totally my mistake. So, back in the lift tomorrow to refill the cavity with the missing quantity of fluid. I probably put about 250 miles with low fluid level and only acted once so I am hoping that no permanent damage was done.
nycturbovr6 (04-28-2015)
Mine is acting the same way. But mine was acting like that before I replaced the fluid and sleeve. It still does it every once in a while. I went to the dealer to have it reflashed and they told me not to because it had the shift fault. They said that the engineers told them its not recommended because it the transmission may not be able to relearn adaptions because it could be too far out of adjustment and may cause the transmission not to work at all after the reflash. Has anyone heard of this? How true is this? Is the dealer just trying to get rid of me and hope I'll come back after the transmission fails?
aholbro1
08-05-2021 05:02 AM
Rlover
03-30-2016 10:04 PM
Guy-Pierre Boucher
09-16-2015 05:55 PM
