2004 XJR - Source of clunk appears to be the Arnott's Air shocks
#101
Looking forward to your analysis! Be careful when you disassemble them. Chain the spring to something solid while disassembling it in case it decides to go. Note you have to have the right tools for this. Loading and unloading automotive springs, done incorrectly, will kill you.
#102
Received replacement
I have just received the replacement strut (the one on the left in the pic). First thing I did was to inspect the spring perch and it was indeed put together correctly. I shall be installing it later on today and start putting the car through its paces the next few days.
#104
They look awfully close though. A lot of times well known manufacturers will sell their un-badged products to third parties at a discount and the third parties slap their own sticker on the products. That is what may be happening here but that is anyone's guess.
What kind of spring compressor did you use to remove the spring from the shock assembly?
#105
Did you catch the spring seat setup being totally different? On the Bilsteins, it's just 2 parts: larger snap ring, and the seat itself. The SM units use that 3 part design with the non reversible ring (that was sadly reversed in your back unit)
I have a nifty strut compressor with hydraulic jack....eBay 100 bucks. But anyone could use the compressor screws from AutoZone for free. You want to talk danger? Try Mercedes springs on the 107.... They have killed many a backyard mechanic. Damm near took me out when I was in my 20s.
BTW...Welds look different too...
But who knows right? More tonight.
#106
I installed the replacement strut and gave it a whirl. It survived my test drive, which does not say much but at least is hopeful.
#107
#109
Bilsteins are made in Germany. Even if generic no label....I think they will still have a made in Germany stamp. My SM units don't state that anywhere. But Lagonia does have a point...could be an off market label thing.
Here is a pic of my strut compressor. Not necessary for this...but I love having it around and it lives in a corner of my cramped...but highly capable garage.
I'm still missing one rear shock @$@#@!!!
So no install till then. Of course I'll keep you guys posted!
Lagonia (11-18-2016)
#111
#112
I will tell you this.... The Bilsteins are much stiffer. ie= harder to push down on, and rebound much quicker. Side by side its a noticable difference. Thats what im looking for, but may not be what others want. They are certainly not the same shock!
More reports when installed!
#113
It could be that SM chose to emulate the shock rates for the S type sport suspension and not the R specific units. I'm getting excited, gonna get this whale to handle like I want her to. Cost of the new shocks has delayed the upgrade on the XF aftermarket swaybars a bit, but she will be the perfect sleeper!
Hmm, idea for license plate: catnap.
#114
Hybrid conversion update
Can be done with AutoZone free rental spring compressor
Side by side of stock and Bilstein hybrid front units
Strutmasters and Bilstein rear
Was stuck in back to back trials, finally got back to the garage.
Pics of installed units and car ride height to follow.
Been test driving it for about a week. VERY HAPPY! No body sway, bigger sway bars not necessary now.
It's a sport ride, not too harsh, much quicker steering, TOTAL BLAST TO DRIVE! Basically...exactly what I wanted!
High confidence in Bilstein build quality is a nice side effect too
#115
I'm going to go with - those are not Bilsteins. Look at the tapers at the bottom of the shock of the Bilsteins, and the pinch area at the bottom of the generic shock. They would indeed have a number printed on them which crosses with Bilstein numbers and the made in germany - every Bilstein I've seen has this (but I can't say they all do).
It sure looks like strutmasters went to cheaper stuff. I've also not seen Eibach springs that don't have the white Eibach logo printed on them. If they are removed - then they can use anything and say they are Eibach's. BS to me.
#116
Almost one year in, and after 8K miles on my hybrid build.....
COULD NOT BE HAPPIER! After 500 miles the Bilsteins settled into the PERFECT balance of ride quality/control.
chillyphilly (12-13-2017)
#117
Hard Whack noise on large bumps and potholes
I realize your post regarding the Arnott shocks is a year old; but, I am curious as to how it turned out for you and whether new shocks corrected it? I have 3 year old Arnotts on my 08 XJ. However, I am not sure what I am experiencing is an actual shock problem or not. I would not describe my noise as a clunk; it is more like a hard whack when I hit a pothole or sizeable bump. I can hear the shocks working normally on lesser bumps. It feels to me sort of like there needs to be a rubber seal or cushioned buffer of some type between the shock and the metal part of the car which the upper shock bolts into. All bushings were replaced at approximately the same time as the shocks. Any advice from anyone is appreciated.
#119
