2004 XJR stalled after being restarted
Just an update. There appeared to be a short. Was able to refire but only hitting on 4 cylinders. replaced wiring harness and ran on all 8. Mechanic said there was a short on in the coil, COP on number 8 and this led to problems???
Engine is running, but OBD says error communicating with ECM, however the OBD scanner shows most functions but I dont see any misfire indications. SO not sure what is going on with ECM and OBD not speaking, but the OBD picking up the other systems, tranny, Suspension, etc.
The mechanic should know whether current or old code(s).
Don't clear wildly - OBD codes self-clear when the fault is fixed - as it also clears all the OBD monitors (needed for such as smog checks) and if they fail to set again you can be in a terrible Catch-22 state where the car can't flag codes due to unset monitors that can't set due to the fault(s)..
Don B (03-14-2018)
