2004 XJR suspension problem after repairs
![Question](https://www.jaguarforums.com/forum/images/icons/icon5.gif)
I've unsuccessfully searched the forms for a similar problem.
I have a 2004 XJR with about 120k miles. Due to a leaking front shock, both front shocks were replaced with Arnott units. An air suspension fault continued to show up, and the repair shop diagnosed a faulty air compressor.
The air suspension fault code cleared after compressor replacement. However, I noticed the following day that the passenger side of the car - both front and rear - was significantly lower than the driver's side after sitting for 30 minutes or longer.
Opening a door would immediately cause the passenger side to raise to a normal level. No fault codes would appear when the vehicle was started.
The local repair shop diagnosed a leaking passenger side rear shock. Two new Arnott rear shocks were installed, however this did not fix the problem. They are suggesting a problem with a solenoid.
Does anyone have any ideas or suggestions on how to proceed?
Paradigm
06-15-2019 05:59 AM
Fraser Mitchell
10-01-2015 04:06 AM
Donzi
09-07-2015 12:06 PM
