2004 XJR - Throttle Body / TPS issue
Old 02-11-2015, 08:05 PM
Lagonia's Avatar
The throttle body has been replaced and with 400 miles on the new throttle, I feel pretty good.
Getting ready for heart transplant
The tricky part are the two coolant hoses. Remove the 4 holding bolts and twist the throttle body around so that you have more space to remove the coolant hose clamps
Coolant hose clamps are more accessible
New on the left, old on the right
No surprises, pretty straightforward overall.
The following 2 users liked this post by Lagonia:
jackra_1 (02-14-2015), NCamie (10-28-2015)
Old 02-14-2015, 11:40 AM
jackra_1's Avatar
Received 1,756 Likes on 1,327 Posts
Besides being dirty were there other issues with the old unit?
also did you lose much coolant when doing the swap?
Old 02-15-2015, 10:09 AM
Lagonia's Avatar
Other than putting me in limp mode, I did not have any other issues that I could attribute to the throttle body.
I lost very minimal coolant. Pretty much a non-issue there.
jackra_1 (02-16-2015), NCamie (10-28-2015)
Old 02-25-2015, 01:50 PM
MCSMCS1's Avatar
Originally Posted by DonsXJ8
Just had my two tire TB plug fall apart last night. I was driving home and got the STD. engine systems fault and when I was poking around it decided to unplug the connectors to the TB and the two wire connector crumbled. So in my search for a replacement connector I stumbled upon this thread and found it useful. I also found another possible option other than the plug Lagonia ended up using. I'm going to order some and thought other may have some interest.
SouthBay Fuel Injectors
Did this 2-wire connector replacement work? It looks like a better potential fit with the design shown in your link above.
Old 03-02-2015, 09:04 AM
Well that sucks. But at least you're prepared with a replacement TB. And that connector won't be a problem anymore. Good luck.
Old 03-11-2015, 04:32 PM
Muddybear's Avatar
Does anybody know what size head the screws holding the TPS on are? Are they Torx head? I'll be replacing mine shortly and like to plan ahead.
Old 03-11-2015, 06:40 PM
Received 4,461 Likes on 2,427 Posts
5-point Torx, special security bit, you'll find them on eBay.
  #28
Old 10-22-2015, 11:10 PM
emorillo2's Avatar
Exclamation
It does not fit. The side grooves are not centered and the top groove is not wide enough on Denso connector. Pictures are from X-Type TB, but I assume is the same as X350.
Side grooves not centered on denso connector.
Top groove not wide enough on Denso connector.
Side grooves not centered and top groove not wide enough on Denso connector.
I continue to search for a replacement connector, there just has to be one out there.
Old 10-28-2015, 08:52 AM
NCamie's Avatar
Hi Lagonia,
I really appreciate your posts on this TPS problem. Seems I'm having the same issues. When I get home I plan on looking at the wire connections to it, but I am curious to know where you sourced your new throttle body unit? I think I may have seen some on eBay, but I'm hesitant to purchase from there. What are your thoughts?
Thanks, Norm
  #30
Old 10-29-2015, 07:05 PM
Lagonia's Avatar
Originally Posted by NCamie
Hi Lagonia,
Thanks, Norm
I got it at SNG Barratt (SNG Barratt - The Ultimate Jaguar Parts Specialist) and the part number is C2C20541. I have installed it last February and have since put 8,000 with absolutely no issues. The car is still my daily driver.
  #31
Old 11-02-2015, 06:37 PM
emorillo2's Avatar
Talking I found the connector!
The connector is available for sale here: Jaguar x Type Throttle Motor 2 Way Electrical Connector | eBay . It fits and works perfectly .
Get them while they last!
Lagonia (11-03-2015)
  #32
Old 11-02-2015, 10:18 PM
dwclapp's Avatar
emorillo2: Have you tried Ford electrical connector WPT-1269?
[WPT-1269]Motorcraft/Ford Wire Assembly(WPT-1269)
Connector WPT-1269 is in Ford's electrical connector catalog, page 12:
http://www.fordservicecontent.com/pu...torcatalog.pdf
Attached Thumbnails 2004 XJR - Throttle Body / TPS issue-ford-electrical-connector-wpt-1269.png
Tijoe (01-28-2019)
way2far
08-31-2022 09:26 AM
toronadomike
08-07-2022 03:41 PM
kelliott
05-31-2022 05:26 PM
SD96XJ6L
01-12-2022 04:30 AM
Quick Reply: 2004 XJR - Throttle Body / TPS issue
