2005 jaguar xjr rear light problems
This is killing me. This is with HEADLIGHTS OFF. Turn on left blinker, the blinker works fine until I step on the brake then the left blinker is dim and right brake light (LED) flashes dim with the left blinker. Turn on the right blinker and everything works perfect. This is where it really gets confusing. With HEADLIGHTS ON, turn on left blinker without brake lights on and the right tail lights, the license plate lights flash with the left blinker. Apply brakes and the right brake light flashes with the left blinker. Only the right reverse light works with or without headlights on. Swap tail light assemblies (left to right) and it's the same scenario on the same sides. Sometimes after driving the car awhile everything works fine.
Received 2,636 Likes
eddiedoughty (03-22-2016)
You are right. I cannot find where the bad ground is. I own a 89 xjs and a 2000 xjr. So the ground is the first place I looked. Because there is no common link between the lights with the problems (brake, reverse, blinker, fog), it has to be a ground or a control module. I don't have a wiring diagram yet. Thanks again.
Check the ground at the connector coming straight off the back of the tail lamp inside the trunk. If you put in a jumper wire on the ground, and put it to a good ground connection in the trunk, see if this helps. Just might need to do a wire repair and run a new ground wire.
The REM controls a lot of different things for the rear of the car, as this car and the S-Type are what Jaguar calls Zoned Partition, meaning, the REM controls everything in the rear of the car, and the front or general electronic module controls everything in the front, such as lighting. Haven't seen any issues on these cars with the REM's. When checking fuses, always pull them out and look at them.
Looking at the wiring diagram, the rear lights aren't fused themselves. Most likely a faulty ground.
eddiedoughty (03-31-2016)
Hi, yes I believe the problem lies in the pcb on the bottom of the fusebox. Because I needed my car I just ordered a used fusebox complete with fuses off eBay for around £20. Took me about 15mins to swap it out and I was amazed it had fixed it, I too was at my whits end with it and found the idea of the fusebox after googling around one evening, it seems to be becoming a fairly common fault.
