2005 Jaguar XJR Removal and Value
Old 08-08-2022 | 03:40 PM
karlward96's Avatar
Default 05 Jaguar XJR Removal and Value Catalytic Converters
I am looking at removing my 2005 Jaguar XJR Catalytic Converters and get the scrap value and just straight piping the car. Does anyone know how to remove the Cats and also the scrap values? I just got $1100 for my 2002 Jaguar XJR Cats.
Old 08-08-2022 | 05:06 PM
xalty's Avatar
https://www.ecotradegroup.com/en/pro.../2w93-5e214-ec
two 15mm nuts one band clamp. no torch or induction heater = good luck
Old 08-09-2022 | 11:08 PM
karlward96's Avatar
Thanks for your help. Are these just under the car?
Old 08-09-2022 | 11:32 PM
Snowcone551's Avatar
Keep in mind if you remove the cats you are going to have a check engine light on from the post cat O2 sensors. Sounds like a lot of work for not much gain. And the car will smell stronger of gas fumes
Mike Hoepfinger
02-20-2017 11:40 AM
electrovolt
08-01-2014 06:22 PM
GerryXJR
02-18-2013 09:42 AM
Quick Reply: 2005 Jaguar XJR Removal and Value
