2005 Super V8 OEM wheels. Why 19 inch?
Received 13,426 Likes
Sean,
To sum up my understanding of the general compromises involved in selecting a wheel/tire ratio:
The larger the wheel and lower the tire aspect ratio/sidewall height, the better the steering and handling, but the harsher the ride; also, the greater unsprung weight, because most aluminum wheels weigh more than the equivalent diameter of air-filled tire, resulting in reduced suspension damping efficiency and some additional loss of nimbleness and ride comfort.
The smaller the wheel and the larger the tire aspect ratio/sidewall height, the worse the steering and handling due to increased tire roll when cornering, but the greater the comfort due to increased air compliance in the tire.
Just to add another brand of tire to consider, I have had great success with Yokohamas on our Jaguars for their combination of ride quality, great handling and precise steering, low noise, decent treadlife, and lower cost compared to Michelin and Pirelli. Their current model is called the AVID ENVigor, which isn't rated well for snow and ice but otherwise is rated competitively with, and even superior to, some of the Michelin Pilot models and Pirelli P Zeros, yet at a significantly lower cost. When the Pirellis on our X350 wear out, I will definitely be considering Yokos for the next set.
My two cents!
Cheers,
Don
My two cents!
Cheers,
Don
Sean W (03-22-2014)
Well my Tucana wheels arrived this week. I did a quick check for clearance fitment and having the Michelin Pilot MXM4 V rated tires (235x50Rx18) installed today. Here in Minnesota, the tires run $946 after tax and rebate of $70. Includes mount valve stems, balance and lifetime rotation. I still can't see the grass (snow cover), but we've had enough rain that all the salt is off the roads. Almost cruising time!!!
I will keep the 19" OEM with Blizzaks on them in the garage in case I ever decide to drive in snow, though not bloody likely.
Thank you to everyone for your help!
The offset of the 17" OEM Jaguar wheels is exactly the same than the one of the OEM 18". I also have a 17" set for winter in addition to my set of 18" Coventry. Btw, the 17" are forged and much lighter, very nice wheels!
metalmarty
09-11-2015 07:05 AM
FS[SouthEast]: 2005 Jaguar XKR Convertible Supercharged
divingmom
08-25-2015 07:54 PM
