2005 Van den Plas big leak from back of engine
There's a coolant hose that runs underneath the intake manifold within the "V" valley of the engine. When it ruptures, the coolant spills into the valley and spills out the back.
The hose itself is only around $15 but a garage will charge you around $1000 for labor because the intake manifold and a bunch of other bits need to be removed. If you're handy, you can do it yourself over a weekend if you take your time and follow the steps. Do a search for valley hose and you'll get more info.
NDW (07-21-2017)
AC0FC
03-16-2017 09:36 AM
