2005 wipers not working
The fuses are fine. I presume, from searching the site, that a relay has blown. I phoned my jag dealer last week, but they haven't phoned back, so would like to fix it myself.
What is the part number, where can I get it from, and is it easy/doable to replace.
Thaskn guys.
Thaskn guys.
Check fuse 26 40amp in engine bay fuse box. Then check relay 4 then relay 8, also both in fuse box in engine bay. If everything ok there, either switch or wiper motor. You want to check the relays with switch on. If no power, you need to check out put from front electronic module. Before any of this though, disconnect battery 5 minutes and try again.
KarimPA
09-03-2015 07:32 PM
FS[Western US]: XJS Wiper Motor Upgrade- 76-88 - Electrolux Style
XJsc-guy
09-02-2015 11:43 AM
