2005 xj8 and acm
2005 xj8 and acm
Only recently got a 2005 xj8. The car has stock radio, no cd changer, no nav, no touch screen. Tested iPod/acm in another 2005 xj8, but with touch screen where it worked. Installed acm in my car -> cannot control iPod other than track change! iPod plays only if you connect iPod to acm when playing. This is a 5th generation iPod. ACM manual reports that the acm treats playlists as discs and one should be able to change playlists by key pad 1-4, and should be able to go to menu as disk 6. Once in disk 6, pressing ff for more than 2 secs selects the menu item. My acm does not do any of that. Dealer is getting me a new acm.
According to manual, connecting iPod should show Jaguar logo on iPod. On my setup this happens only when the iPod is playing. If, the iPod is asleep, connecting the iPod flashes"ok to disconnect" and the iPod main menu continuously. And cannot play iPod then.
Interestingly, trieda 3G iPod with this same setup. Granted that iPod was not asleep when I connected, but I was able to control the iPod as advertised.
Am thinkingmy acm needs a firmware upgrade. Does that sound plausible? Or, do I need a new acm? Should I try to restore my iPod to original settings and test - the current setting worked in a different car, so I skeptical about my iPod being bad.
Thoughts? I would really like to get the acm working. I think the fm modulation style of iPodding is unsafe!
RE: 2005 xj8 and acm
After a lot of trial and error, my iPod now works in my car. What happened to make it work, you ask. Well, my dealer had checked with Jaguar, and they mentioned my symptoms seemed like a bad connection between the iPod and the dock connector. I am not so sure about that though. The one thing that had changed between the times it wouldn't play, and the time it played, was that the car (and thus the acm) were off for the full night, and the iPod was also off. I connected the iPod one morning, turned on the car, and voila'. It works. Since then, I have been able to play the iPod fine.
Had the iPOD integration installed by some other than the dealer (though the dealer uses the same outfit and warrants work done by them). The integration with the NAV head unit is aweful so I had them split in a regular RCA jack and the USB connector. It's easier just to plug the iPOD into the headphone jack (unless you need power of course) and use the iPod itself to control the tracks. I also had DVD player and headrest LCDs installed so I have 2 additional RCA jacks and 1 AC jack (1 in trunk, 1 in rear arm rest). Plugging my ipod into the rear arm rest RCA is the only way I can still retain control of the CD changer without shutting the car down. Really poorly designed integration. They could have built a tree interface into the touch screen that would have smoked all of the stupid iDrive interfaces out there.
