2005 xj8 heater core looking for cheaper alternative
If you follow the flushing route, be aware that it is the surface area available for heat exchange, not the flow through the matrix that counts. Many of these pass the coolant OK, but the cabin remains cool. Flushing on its own is useless, you need something with a dissolving action on the blockage material. I'm not sure what that is, it may be citric acid. The problem with chemical-assisted flushing is that if it doesn't work very well, you've spent a lot of time and effort for nothing, and will have to take it all apart again to fit a new matrix. This is why I bit the bullet and had a new matrix installed.
You can buy aftermarket as said earlier. I also found the same one here: -
Jaguar XJ6 Heater Matrix | X350 X358 Heater Matrix
