2005 xj8l air suspension fault
Old 11-21-2018, 06:58 AM
EsRay's Avatar
Okay, Thanks - That order of service makes good sense...…..All I need to do now is figure out which of my front Shocks is leaking...The right hand (when viewed from the L/H/D drivers seat) one I had replaced here some 9 months ago (not at all sure of its provenance), or the 13 year old original on the left (Drivers side) where the height sensor is located......
The difficulty is that the front does not noticeably drop when the car is stationary - Even over a night or two? When the Suspension Fault light comes on (about 5 - 10 minutes after I start driving), all I have to do is pull over, switch off, start her again and out goes the light and the front comes back up fully within 30 seconds and the compressor switches off?
However, I have read Don's excellent 'Suspension Sticky' and (from what I garnered from that) it must be a shock leaking when the car is being driven and leaking sufficiently badly to deplete the air reservoir beyond its ability to compensate?
Old 11-24-2018, 01:44 AM
EsRay's Avatar
UPDATE: I fully charged my battery and did a 'hard reset' and my amber suspension fault light appears to have gone away - Leastways it has not reappeared whilst doing the same runs as I did when it appeared previously? Not had the 'kangaroo bouncing' suspension to go with it either!
Obviously I need to do some more runs without the fault appearing before I can be absolutely sure, but I will keep you posted in case this (possible) remedy could become helpful to another member?
Old 11-24-2018, 10:34 AM
Wingrider's Avatar
Wink
Hope for the best, expect, & prepare for the worst, you'll never be disappointed.
The following 2 users liked this post by Wingrider:
EsRay (11-24-2018), Gatorman67 (02-13-2024)
Old 11-24-2018, 01:25 PM
EsRay's Avatar
Wingrider, I am ex-Royal Navy who joined up for the fun of it in 1972 and now 62 years of age I am forced to agree 100% with you!!
Old 11-24-2018, 08:11 PM
Wingrider's Avatar
Us old duffers were raised way different from todays youth.
Almost 69 myself, & i remember being told that, from as far back as my memory goes.
Whose gonna do for you, if you don't?
No body thats who!!!!!!!
Off your a--, and on your feet.
The following 3 users liked this post by Wingrider:
EsRay (11-24-2018), Gatorman67 (02-13-2024), jackra_1 (11-25-2018)
Old 11-25-2018, 03:58 AM
EsRay's Avatar
Wingrider, I have posted a new thread because I thought it might help another forum member; i have pasted the address below because you deserve to be kept in this loop?
https://www.jaguarforums.com/forum/x...-reset-211032/
Mugatu
22
06-23-2020 01:50 PM
cissdm
05-03-2016 06:02 AM
KarimPA
09-12-2015 08:15 AM
philwarner
09-03-2015 10:14 PM
arnoldmilk
09-03-2015 07:42 PM
Quick Reply: 2005 xj8l air suspension fault
