2005 XJ8VP: "Restricted Performance" AGAIN!
If I do not drive my 05 XJ8VP regularily, I get the "restricted performance" message. I get the code for the left driver's knock sensor (USA LHD). I think the sensor is indeed fine because the car hesitates badly when I accelerate with the RP message. If I keep driving it (and accelerating often), the hesitation clears completely and the RP message goes away. The car will then run perfectly until I let it sit up for another few weeks. I am thinking I have a fuel injector(s) that need replacing? I used a bottle of Techron cleaner, but still have the issue.
Any guidance much appreciated!
Richard
Richard
Richard
Richard
Richard
Richard
If your value(s) are not in spec then you need to replace the knock sensor meaning you have to remove the SC
benzjag
01-04-2021 06:28 PM
carlorner
09-11-2011 04:56 PM
